Used Up User
Has anybody used the spare tire?
Just wondering if anybody has actually used the spare tire, jack & compressor at the side of the road or is it deadweight?
Just wondering, because I have some audio amps that will need a home . . . Ian
'87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- |
I never used it but I tested it once for the same reasons - well, not an amp - but I figured if the collapsible is dead, no sense carrying it around.
Nope, it held air and collapsed back after the test. Not 100% as tight as before though, it was a tighter squeeze ! |
For my peace of mind, I'd keep a spare. And yes, I've used my spare...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Used Up User
You're not telling me what I wanted to hear.
Ian
Sultan of Sawzall
Yes, we've used it!!! My wife & I were on I-40 back in Nov. in our '86's (returning from PorschePalooza) when she had a "rapid deflation" of a new S-03 (left rear) in her car...we were in the middle of nowhere (actually 6 miles out of Alma, Ark.)...1st time I used the spare. My thoughts were: "Is this thing going to inflate?" and "Will it be OK to get us down the road?" Luckily, the answer to both questions was yes. It takes forever for the tire to inflate, but it really looks cool as the sidewalls take shape. We found a WalMart open that Sunday afternoon, had them plug/patch the S-03, and we were back on our merry way. After being there 20 years, it still worked like a champ!
![]() *EDIT* I'm glad it worked, as I tried "fix-a-flat" and the hole was just a tad too large for that to seal. Just fizzed and kept spitting it out when we tried to limp it away..I do carry a can in the trunk, but just glad the spare worked after the goop did not.
Gruppe B #319 2 '86 911 Carrera coupes (red & white) '66 Corsa convertible 140/4(red) '66 Monza coupe 110/PG(white) '95 993 cabriolet (wife's) Last edited by rouxroux; 01-19-2007 at 12:48 PM.. |
I'll add this: The new 987/997 don't have a spare at all, just a can of goo. I had a sidewall blow out on me in the 987 last year and the goo was useless. I got stuck waiting for Porsche assistance for 2.5 h - not in a particularly nice area either. I went out and bought a 986/996 spare and stuffed it in the car ! So no, I think losing the spare is not a good idea ! It's like insruance, you don't need it when you have it but if you don't have it, Murphy will bite you in the a$$! |
Non Compos Mentis
I've used them- They make great weights to hold down the pop-up shade at John Walker's swap meets.
And I go home with a couple less than I brought. |
Use my space saver spare-worked great. I would keep it.
Pat
10 Ford Raptor 86 930 |
Anachronistic Anomaly
What do you do if you don't have the compressor?
Can of air or something like that?
IG@ the_derek_whitacre |
Sultan of Sawzall
Trust me, you'll NEED the compressor. And if you don't have the factory one, there are great aftermarket ones out there for not much money. It take quite a while for the stock compressor to inflate the tire.
Gruppe B #319 2 '86 911 Carrera coupes (red & white) '66 Corsa convertible 140/4(red) '66 Monza coupe 110/PG(white) '95 993 cabriolet (wife's) |
I used it once, the rear dunlop on the 17" blew, I rode it in the deflated shape slowly on the side for a mile to a gas station to put air in it,and then home another 40 miles, I would keep it !!
84 911 Carrera SOLD not forgotten 01 911 C4 factory Aerokit ![]() 76 914 rust bucket SOLD !! 03 Boxster S sold 98 944 S2 G Red,sold 04 FRC red Vette |
Retired Member
Ian, I fabricated a bracked for my amp and mounted it on my spare tire.The bolt for the spare is drilled through my amp bracket.
I've never used my spare but I've checked to see if it holds air. Brian
80 911 SC sold 17 Tahoe 07 Z06 Corvette
I'm with Bill
FYI - My MINI had no spare but had runflats which I HATED.
I swapped the heavy 17" rims and tires for 16"Kosai K1's and Yoko pradas. I then purchased a 12V pump, a tire plug kit and a can of fix a flat. I never had to use them. I have never had to change a flat on the road but then again I am anal about tires and check them every week for inflation and punctures. Especially on my wifes car.
1978 Mini Cooper Pickup 1991 BMW 318i M50 2.8 swap 2005 Mini Cooper S 2014 BMW i3 Giga World - For sale in late March |
Band.
As soon as you take it out, you can pretty much guarantee you'll get a flat out in the middle of nowhere. It's Murphy's law.
I used a similar spare and the compressor on an Audi once. It really is a cool thing to watch. But you definitely need the compressor. It takes a while, too.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
Used Up User
OK. You are all right, of course. If I took it out I would end up in the boonies with a flat & no cell service. At night. Cue the banjos from Deliverance here . . . I'll leave it in.
Brian I was thinking along the same lines. My guy at Focal sent me 2 amps - a 2x75W & a 1x400W - one for the door components & one for a pair of 8" sub drivers. So I've been searching the archives for locations that make sense that will leave some trunk space for other crap. Maybe one above the wheel as you have in the shallow end of the trunk & one under the passenger seat . . . Ian
u got a purrrty mouth..ian..
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
Retired Member
Ian, I only have one amp. It measures 10by12 by 3 inches high. If I used a larger piece of aluminum it may work. As a side bar I was told the spare may protect the fuel tank in event of a collision. In saying that the spare is the first thing I see removed from the trunk at DE events.
Brian
How difficult is it to get a pre-99 911 flat tire in the back seat ?
I carry large trash bags just in case the flat needs to be stored. |
Used Up User
Brian
Here is a scale picture. I'll make a board that I fasten with wingnuts to the spare. Then I can pop it off to access the spare. Ian
