-   -   Search help? (http://forums.pelicanparts.com/porsche-911-technical-forum/324323-search-help.html)
notfarnow 01-11-2007 12:42 PM
Search help?
I'm trying to read up on 3.2 valve guides.
When I search:
3.2 valve guides
I get results based on valve and guides, but not 3.2
When I search:
Carrera valve guides
I get results based on Carrera, valve and guides
Am I missing something? Can you not search for numbers, or is there a minimum character limitiation? Makes it hard to do searches for specific engine types by displacement.
Early_S_Man 01-11-2007 01:25 PM
There is a 3-character minimum, and punctuation doesn't work in a search string, or is ignored.
notfarnow 01-11-2007 02:11 PM
Thanks for the reply!
That's not much help when you're searching for engine specific info, like 2.7, 2.4, 3.0, 3.2. Might make sense in some applications, but it sure seems like a troublesome limitation.
I wonder if it's a technical limitation, or a parameter that can be set or adjusted.
