Guest
Posts: n/a
71T - Bosch replacement for Marelli distributor
Quick question. Does anyone know if a bosch distributor from a 69T will work on a 71T as a replacement for the marelli (sp)? Advance curve ?
Thanks, Peter. |
Guest
Posts: n/a
Yep, it will work fine! But, before you just swap it out ... disassemble, clean, and check the Bosch unit for worn bushings. If any play more than 0.001" can be felt ... wobble at top or bottom of the shaft, replace the bushings with standard replacement from a local industrial bearing supply. The aluminum bodyshould be heated to 325-350 F for 20-30 minuted before attempting to remove old bushings.
Chill new bushings, heat dist. for easy installation. Lube with Bosch grease -- Pelican has it. Be sure to replace felt 'plug' in center of shaft, below rotor, and put a few drops of engine oil on it upon reassembly, and every time you change oil, check/adjust valves or sparkplugs. Good luck! ------------------ Warren Hall 1973 911S Targa [This message has been edited by Early_S_Man (edited 10-25-2000).] |
Guest
Posts: n/a
Thanks Warren. pete.
Guest
Posts: n/a
I replaced the Marelli in my 1971 911T with a rebuilt Bosch from a 1968 911. It runs fine and now I know I can get tune up parts (rotor, points and cap) which were almost impossible with the Marelli. I am glad that I made the change.
------------------ Bob Thayer 1971 911T rthayer@hdrinc.com |
Guest
Posts: n/a
Hmmm, the bosch distributor I purchased arrived today - It has a vacuum advance on it. I'm pretty sure (from memory)the marelli does not. The only numbers I can see on the Bosch unit are JFUDR6 and 0-231-169001. I'm assuming I just wasted some $. Does anyone have any ideas what I have just bought ?
Guest
Posts: n/a
That is a '72 T distributor, and the vacuum unit provides 10 degrees of retard at idle, for smog control. The overall advance, which is set at 6000 rpm (VERY briefly) with the vacuum hose off, is set between 31 and 38 degrees. Then, without the vacuum hose attached, the following values are checked to verify the advance curve:
At 1000 rpm -- 3.5 to 6.5 degrees Before TDC 1500 rpm -- 4.5 to 14 degrees Before TDC 2000 rpm -- 16 to 24 degrees Before TDC 4000 rpm -- 24 to 31 degrees Before TDC At 900 rpm idle the spec. to be checked, with vacuum hose attached, is 5 degrees After TDC, +/- 1 degree. The above data is from the '72-'73 factory spec. book. ------------------ Warren Hall 1973 911S Targa |
Guest
Posts: n/a
Thanks for the info. This does, I assume, mean that I am now the proud owner of a big greasy bosch paperweight.
Guest
Posts: n/a
Not unless you want it to be, Pete! It is usable without the vacuum retard, with the same specs for the advance curve I gave ... the only consequence of no vacuum retard is that your idle advance will be pre-smog at 5 degrees nominal BTDC. No effect whatsoever on the way your engine runs ... except that it will be more reliable than the Marelli! Good luck!
Guest
Posts: n/a
Marvelous news! thanks again.
Guest
Posts: n/a
I replaced my stock 71T distributor with a 69 S Bosch on the recomendation of the guys at Doc & Cy's out of Indianapolis. Haven't really been able to get it dialed in yet. Any suggestions? Thanks, DaveJ 71T
