RETIRED
Joe Bob's Avatar
Ah Fuch....just lost 1st & 2nd gear....
All of a sudden....lost 1st and 2nd gear in the 930 4speed box....limped home in 3rd.....
The coupler looks tight. Internal shift fork??
2012 ML350 3.0 Turbo Diesel
Old 01-08-2007, 10:57 PM
haycait911's Avatar
I like that... 'fuch', covers a lot of situations.
Old 01-08-2007, 11:13 PM
RETIRED
Joe Bob's Avatar
No HAHA!!!! Or any suggestions?
Old 01-09-2007, 06:44 AM
Well, this is sort of obvious but, I'd check the rest of the bushings in the linkage too, before condemning the internals of the box. If all of the linkage is nice and tight and adjusted where it should be, then....
JR
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle
Old 01-09-2007, 07:14 AM
MBruns for President
JeremyD's Avatar
I'd keep the cab
Old 01-09-2007, 08:49 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
Soooo.....
- lost rear transaxle in the 356
- lost 2nd gear in the 3.6 cab
- lost 1st and 2nd in the Turbo
maybe you wanna try a Sportomatic, eh.....
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 01-09-2007, 10:25 AM
the the is offline
Maybe check in the glovebox.
Old 01-09-2007, 10:27 AM
MBEngineering's Avatar
HI I think not with that list of failers, you will only loose the park lock and poss rev' gear, any way back to the 930 box onto the ramps or your jack/axle stands and drain the oil ,then drop off the selector plate to inspect the selector bolt, as 1st and 2nd has gone missing and the shaft could have turned/not operating the selector, also the roll pin in the shaft could have come out??
out off hear in the photo bellow
if the linkage checks out OK then drop the selector plate and have a look.
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Old 01-09-2007, 10:51 AM
ischmitz's Avatar
Well, after taking the shift fork cover off and draining the new filling of Swepco after less than 100 miles driven here is what I found:
1. No parts were in the oil.
2. The selector forke is firmly attached to the selector fork rod.
I had difficulties to engage 1st or second by prying with a large 3/4 extension because I did not get a good leverage laying under the car with gear oil dripping into my eyes. But at this point I suspect the spider to have snapped and that is what causes 1st and second not to work. The next step is to drop the engine/tranny and crack the tranny open. Whey, what fun....
Ingo
Old 01-12-2007, 09:33 AM
Elombard's Avatar
what was the situation when you were driving, hard accel?
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 01-12-2007, 10:22 AM
RETIRED
Joe Bob's Avatar
The circle clip that holds on the idler gear inside the cover plate fell off......******* .75 part.....
The trans was semi locked in two gears...but had third gear operable....really wierd.
We had three people scratching our collective heads....looking hard for something wrong....we pulled the lower gear stack apart....nothing.
Put it back together, shifted fine....EVERYTHING looked pristine.
We looked again at the coupler...fine, we looked at the shifter and its internals......
Then I had a brain fart...hey, look at the cover plate....the reverse idler gear fell out in his hand when he turned it over.....
To answer the prevous posters question....I simply came out, started the motor and no first gear. No hard launch, no boom, nothing.....
Old 01-12-2007, 04:48 PM
pjv911's Avatar
Send a message via AIM to pjv911
Mike if anything else needs attention I have a 930 tranny for parts.
Kurt
Never drive faster than your gaurdian angel can fly.
82 SC w/965S eng and G50 6:1 hp/w ratio
72 911t 2.6 twin plug and 72' 911t 57k orig 1 own miles
65/66 912 1 owner 76k orig
01' Aston Martin DB7 V12 Vantage Coupe 6spd
Old 01-12-2007, 05:02 PM
RETIRED
Joe Bob's Avatar
Thanks...but the previous owner had Galen @ Werks II go thru it before it went into "storage"......so I'm just gonna replace the clip and the nuts on the end of the shafts....
Old 01-12-2007, 05:04 PM
RETIRED
Joe Bob's Avatar
Another good thing...with the engine and trans out, I can install the new gas struts for the rear deck lid easier.....
Gotta do the front ones too. If I remember correctly, the driver side bottom is a real beeeyotch......
Old 01-12-2007, 07:23 PM
