Inspection of my 86 Carrera identifies grinding when shifting to first gear or reverse while moving as bad first gear syncro. Mechanic said not to worry about it, as long as I do not mind having to be stopped when shifting to first. Told me to wait until I need a clutch or other engine repair that required removing the engine.
Will changing the trans fluid/lube help at all, or is there an additive/flushing that could correct or minimize the problem? Probably a dumb question, but I do not understand the mechanic's of the trans/syncro, so if anyone could explain the basics, I am curious to know. Any idea on/if other gear syncro go out and how long (miles) til you think I will need a re-build?
durn for'ner
Welcome!
Many of our old beloved 915 boxes have pretty beat up first and second synchros by now. The 915 in general takes a bit of tenderness and smoothness to get along with. If you can live with it I would wait for a clutch work. Make sure all the gear shift bushings are OK and the coupler is properly adjusted. Likewise the clutch. New lube can be an improvement but will not change the fact that the synchros are worn. Many 915 owners like Swepco 201. Also, please try the search button. The subject has been covered many times. And post pics of your car.
Markus Resident Fluffer Carrera '85 |
Registered abUser
Welcome to the 915 trans. Few if any of us can downshift to 1st at any speed over 5 mph. Second gear will get you going easily from any rolling stop.
Somatic Negative Optimist
86911sc:
Do as your Mechanic says: Come to a full stop for first and shift gently into second meaning: Not too fast from 1st into 2nd. The 915 never was a fast-shifting transmission even new. Ensure that the bushings in the shift housing are good and the shift-coupler is good. Changing oil doesn't hurt but worn synchros are worn synchros. Do a search on this subject here, it's been covered many times.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Schleprock
Agreed on the search. The subject has been covered very thoroughly here and you will find a ton of info and pictures.
In the interim, you may try double-clutching also. It helps spin-up the gears to match speeds and takes away some of the work the synchronizer assembly must do. But, if your gear's dog teeth are thrashed, no amount of double clutching is going to help much. If two parts don't mate well because of misshapen metal......... you get the picture. Here's a couple to get you started. The second one is VERY informative due to the replies from those who have been servicing these transmissions for MANY years. 915 slider teeth: how worn are they (pic) 915 Trans rebuild-internal diagnosis
Kevin L '86 Carrera "Larry" |
Immature Member
When you change your tranny fluid keep an eye out for little metal teeth. These would also be an indicator that it's time.
1984 Carrera Coupe = love affair 1997 Eagle Talon Tsi = old girlfriend (RIP) 2014 Chrysler 300 AWD Hemi = family car "Lowering the bar with every post!" |
Grinding into reverse when stopped is not indicative of a synchro problem ... it is a clutch maladjustment or pilot bearing problem. Reverse gear has no synchronizer!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Thanks for all of the responses - got somethings to check now.
Here is the link to where I uploaded some pictures. This gallery requies images <100K, so they are a little grainy ...... |
Immature Member
Just noticed your reg'n date. Welcome aboard!
