'69 oil tank dipstick
I lost my oil tank dipstick and can't seam to find either a new or used one. Would appreciate someone posting dimensions as I guess I will have to fabricate one. Thanks in advance. Bob Shafer
Old 01-26-2007, 05:46 AM
Robert. I think the simplest thing to do would be to put a WTB in the for sale section. I bet there are thousands out there that people will want to sell you.
Marv Evans
'69 911E
Old 01-26-2007, 08:24 AM
Marv
Thanks for the suggestion, but I did that and got no replies. Bob
Old 01-26-2007, 09:54 AM
Did you drop it in the oil tank or did you acctually loose it. You can probablly fish it out of the oil tank if it is in there. Use a coat hanger to get it out.
1972 911T MFI
1995 911 C2
Old 01-26-2007, 03:37 PM
Tryed that too,but apparantly laided it on the deck lid and drove off. Bob
Old 01-26-2007, 04:13 PM
Bump
Old 01-27-2007, 04:06 PM
Robert,
Hang in there. I can't believe nobody has come up with a lead on a dip stick for you. Almost every other person on the board has a '69.
Marv Evans
'69 911E
Old 01-27-2007, 04:42 PM
Carrera Charlie's Avatar
Bob,
I just went out to my '69 911E and took some photos for you:
The length is 11 13/16" from loop to tip
There is a curve to it as shown in the following photos, along with three detents along the length:
Hope this helps! Good luck finding your replacement dipstick!
Regards,
Charlie - GruppeB #013
'69 911E Targa
'72 VW Bug
'74 Carrera Targa
'85 LandCruiser (FJ-60)
'89 MB 190E 2.6
'97 Town & Country (family hauler)
Old 01-27-2007, 04:44 PM
Bob,
My apologies ... I only saw you want to fabricate one after my first reply. Here are some additional measurements so you can make one:
The "MAX" oil mark is 3 5/16" from the tip of the dipstick:
The distance from the end of the dipstick to the loop which limits the depth of insertion is 10 3/8":
The center of the first detent is 2 7/8" from the end of the dipstick:
The center of the second detent is 5 1/2" from the end of the dipstick:
The center of the third detent is 7 9/16" from the end of the dipstick:
The bow in the dipstick is 11/16" when laid flat with the loop pointing up away from the surface:
That should do it! Let me know if there are any other dimensions you need.
Oh, FYI the dipstick is 3/16" wide.
Good luck!
Regards,
'69 911E Targa
'72 VW Bug
'74 Carrera Targa
'89 MB 190E 2.6
Old 01-27-2007, 05:17 PM
Charlie
Thanks for the pictures, really appreciate them. Bob
Old 01-28-2007, 04:34 AM
911ctS's Avatar
Send a message via Yahoo to 911ctS
Bob,
I have some early dipstick replicas. They are a bit pricey but look fantastic and are very similar to originals. Lazer cut stainless steel with all the proper bends and dim's.
here:http://www.rebelracingproducts.com/EngineRelated.html
_____________________________
Clint Smith
www.RebelRacingProducts.com
1970 911T ----> RGruppe RS/R (mexico blue)
1995 993 becoming an RS (gran prix white)
Old 01-31-2007, 01:54 PM
scottb's Avatar
May be a bit pricey, but for $40 it's not worth trying to fab your own!
1984 Targa
Old 01-31-2007, 02:35 PM
Clint
Befor I saw your post I ordered a '73 dipstick form our host with the intentions of modifing it to '69 specs. If that does'nt work I will be back in touch. Thanks Bob
Old 01-31-2007, 04:31 PM
911ctS's Avatar
Sounds good!
I think modifing the later style one might work. Just be sure that the overall length is accurate after you put all the little kinks in it. My understanding is that all the kinks along the dipstick (early one) are to prevent the oil from scraping off when pulling it out to check oil level. Since the important sections of the stick can't touch the walls of the tube the reading is vey accurate. Those Germans think of it all.
Clint Smith
Old 02-01-2007, 09:35 AM
