wiper motor wires
I am about to install a new wiper motor and mechanism in my 70 targa. The local wrench pulled it three years ago and after rust repair, paint etc etc I am approaching the on the road stage.
My problem is , the four sets of wires that go on the motor are unlabeled. I need to know which colored wires go to each post. There are three vertical posts and one horizontal at "lets call it the top".
I think that makes 24 possible combinations. The one right one would be excellent.
70 911 targa
47 dodge pickup street rod
restored 54 chev flat bed dump
39 chev suburban project
2000 bmw 528i
Old 01-13-2007, 03:24 PM
There is a proper wiring diagram for your year 911 on the main Porsche page here at PP. (below the 911 BBS there is a link for wiring diagrams). I just looked and see that the wiper motor is identified in the legend and shows the wires and color codes for connecting. Hope that helps.
The information available on site continues to amaze me!
Tony G.
2006 Cayman S
1973 914 1.7 project
"Rules are for the interpretation of wise men and the obedience of fools." Colin Chapman, Founder, Lotus F1
Old 01-14-2007, 08:03 AM
wires,where
I know the wires and colors. What I don't know is which posts which wires go to and maybe it is just me, but I can't figure out which posts go to which wires from the diagrams.
When the parts come I will figure out ground(brown) and with a tester, try to figure out posts for speeds. It might not be a horrible task . Maybe.
Skip
70 911 targa
2000 bmw 528i
Old 01-14-2007, 12:55 PM
Gearbox's Avatar
Hey Skip, just went through the same thing on my 71S, same wiper. However, there were two systems, a three speed and a intermitent wiper set up. The intermitent wiper set up has two aluminum relays bolted to the trunk floor right below the passemger side wiper. These are NLA and were only on the 70 and 71 cars. These are the ones I have. To confuse you more the upfixings article shows the plug configuration incorrectly, the pin 31b and 53 are reversed and all the factory wiring diagrams are somewhat different and I have them all. So, if you have this set up, the following pictures will help you. The first is the wiper plugs not wired correctly, the second is the condensor looking thing that causes the wipers to park, and the last is the incorrect diagram of the plug looking at it from the clock hole in the dash. Reverse 53 with 31b.
Black Yellow is at 12 O'clock, red from the condensor is 9, the brown and grey is at 3 not 6, and the Black and lavender is at 6 not 3. Don't forget the ground that is hidden under the plug assembly. Have a bunch of fuses ready, took me several days before I figured it out lol. Good luck Allan
1971 911S, 1974 914 2.0, 1999 Boxster, 2003 Boxster, 2008 Cayman S.
www.TheLolaRegistry.com
"When you think you are in full control, you're just not going fast enough."
Old 01-14-2007, 01:50 PM
PROBLEM SOLVED
GEARBOX
Thank you for spending the time to solve my problem.. I appreciate it , mucho.
Skip
70 911 targa
2000 bmw 528i
Old 01-15-2007, 04:02 PM
tassie targa 76's Avatar
Just did mine
Here is the 76 version if anyone needs it
project 1976 911 targa
everyday drive 1995 318i BMW
wifes car 2001 c200 kompressor coupe
spare 2006 mazda bravo ute
Old 11-01-2014, 05:19 PM
seafeye's Avatar
Anyone have a part number for that capacitor?
What me speed?
Old 11-19-2018, 03:17 PM
ROW '78 911 Targa
timmy2's Avatar
Looking at one I have on hand, the info on it is:
BERU SK 210/3S
0.5uf 110v
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, Bitz kit EFI.
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 11-19-2018, 05:29 PM
bumping this old thread.
I have a similar config as gearbox with intermittent silver relays and the capacitor mounted under the dash. However, the red stripe and red solid wires coming off that capacitor looking thing go back into the wire harness and its hard to trace them. The black wire hanging off the this "capacitor" however is not plugged into anything. Could that be my "feed"?
1971 911T with a RS spec 2.7 motor
Old 05-13-2020, 09:50 AM
Black wire from capacitor
The black wire from the capacitor can be connected to the wiper motor.
You can also connect the two red wires directly , the capacitor is there for noise suppression.
For 1970 wiper motor, the correct connector is 53a at 9 oclock.
Check my article/solution if you have a 70 wiper setup - connections and wires
'70 Wiper Motor Question
Old 09-20-2020, 06:03 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
