Oel Gauge
Can someone educate me on what is normal for this gauge? I know when its warming up the needle will be at the red mark for a while. But what is normal for this gauge when the engine is warmed up?
Frank 1980 SC Cab Conversion (sold) 1974 914 2.0 RIP rear ended Looking for a 996 Silver Cab 2002-2004 |
Hi Frank,
I discussed this at length on the rennlist forum. Search under 2.7racer. Bottom line, as you know, to check oil level in the reservoir tank, you get the motor warmed up, put the car on a level surface and check the dipstick with the engine idling. If the oel gauge is working correctly, it should be close to what you see on the dipstick. Essentially if the oil is near the high mark on the dipstick, it will be high on the gauge. Conversely if it is near the lower dipstick mark, the gauge will be at or near the red mark. While driving the car the gauge will fluctuate from high to low depending upon conditions. The only time you should use the gauge is when the car is warm, level and idling. It's a good idea to check it for accuracy by comparing the dipstick to the gauge. Additionally the oil in the reservoir tank will gradually, over a period of several hours, drain into the motor until the levels are equalized. This is why the oil usually reads low when you first start up the motor. It takes until the motor has warmed up until the oil levels have normalized.
DOUG '76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's. '85 911 Carrera, stock, just painted, Orient Red Last edited by 2.7RACER; 01-13-2007 at 10:21 PM.. |
Doug
Thanks for the advice wasn't sure how it worked.
Fenderguy, that gauge can be high or low, seemingly independent of the dipstick; but I have found that it's consistent. In my SC, it does happen to match up pretty well with the dipstick. In my 993, correct oil level was right at the top of the red on the bottom of the gauge.
You have any pix of your cab conversion? No need to repost and use up storage if you have already posted. J
Warren Hall (Early S Man), 1950 - 2008 ------------------------------------ 2006 Tri D675 Scorched Yellow 2006 Ducati Sport Classic mono SOLD 1979 SCWDP #0020 Talbot Yellow SOLD |
holtjv
my gauge is acting wierd now with a differnet motor, now when warmed up it stays around the upper redline? Heres a pic
