While reviewing my previous post, I realized that I forgot to mention installation of the front wheel bearing inner grease seal. The grease seal is tapped in using the same method as the races.
The first photo below shows the grease seal (gold color) inserted - the inner bearing must be seated in its race before installing the grease seal. Note that the rubber lip on the grease seal faces outward, away from the hub, to seal against the spacer pressed onto the stub axle (2nd photo) . The lip prevents grease from escaping at the OD of the spacer, and is greased before sliding the hub assembly onto the axle. To prevent grease from escaping at the ID of the spacer, there is an O-ring that slides over the stub axle before the spacer. To replace the O-ring, the spacer must first be pulled off the stub axle. My car was not leaking grease at this point, but I purchased new O-rings anyway since it was easy to replace them once everything is apart. However, I noticed that the powder coater painted over the edge of the spacer (I should have removed the spacers before having the struts powder coated), so even if the O-ring were to fail, there is no way for grease to escape. Given this, I decided to not pull the spacers and to leave the original O-rings. ![]()
'73 911T RoW (Project) '77 911S 2.7RS '76 914 2.0 Early911SReg #2945 |
Frank: Thanks for the extraordinary quality of your posts. Your communication skills match your auto repair skills.
I don't recall seeing a resolution to the adherence issue between JB Weld and either bare metal or the paint you wanted to apply in the torsion tube. Did you get an answer on the ring with the holes? Also, you mentioned in one post using POR15 and Wurth Undercoat (I assume it was Underbody Seal). I visited both websites and it appears they are similar. Under what applications would you use either? Again, thanks for all the time you have put into your documentation. I have learned a lot, especially about metal preparation and finishes, and will definitely be using your thread in the future for reference.
1985 911 Carrera Targa, 2011 911 Carrera S 997.2, 1951 Harley Davidson Panhead Chopper, 1957 Harley Davidson Panhead- stock, 1972 Yamaha 250 DT-1(sold), 1959 Austin Healey (Bug Eye) Sprite- sold, 1959 Austin Healey (Bug Eye) Sprite- sold, 1960 Austin Healey (Bug Eye) Sprite- sold |
Is there powder coat on the seat for the brake discs? It looks like. Not a good thing then, as the seat is very sensitive to be within specs, otherwise discs wont run strait, chattering etc. is the result
Roland 930 Turbo '81 Too many modifications to list |
I never determined if there is a part number for them. IIRC, the holes started appearing after a certain year, and their orientation is consistent. But what purpose they serve (if any), I do not know. I discovered that mine weren't as rusted as I thought they were once I cleaned them up. Quote:
http://forums.pelicanparts.com/paint-bodywork-discussion-forum/792484-correct-colour-underseal.html http://forums.pelicanparts.com/paint-bodywork-discussion-forum/538184-another-wurth-stone-guard-question.html Thanks for reading - I have so much more to learn myself.
Thanks for bringing this up - I assume you are referring to the surface where the front brake rotor mates with the hub? I was also concerned about the powder coating on the hub in this area, so I used a flat file to remove most of it and to ensure that the surface was flat, before installing the rotor. However, I did not take it all the way down to bare metal, so if I notice any issues with the front brakes after I get it all together, this is what I will suspect first. Fortunately, removing the front hubs is not too much effort.
Hi Frank, loving this thread as I am also doing my suspension refresh at the moment as well.
I am also located in Austin, TX and was wondering who you use for the yellow zinc plating and whether you would recommend them. Thanks!
87 Carrera Black/Grey |
Kankl7,
Sorry for the delay in responding - I was spending all my free time last week getting the car back on four wheels for the Hill Country Rallye. The first batch of zinc plating was done by Consolidate Metal Technologies, up in Round Rock. They did a very nice job, but unfortunately decided to no longer take non-commercial jobs several years ago. When I had the bottom of the chassis painted by Jeff's Resurrections (in Taylor), I asked the owner who he uses for plating services, and he recommended Taylor Metal Finishing - just around the corner from the restoration shop. TMF plated the remainder of the parts spread over 5 or 6 jobs. The owner is also a "car guy" and very friendly. Because TMF does these type of jobs between their normal work, they can't always predict when the parts will be ready. I've had them take anywhere from one to three weeks, but the quality is usually nice - and largely depends on how well the parts are prepared before dropping them off. The smoother the metal, the glossier the zinc plating will be (if that's what you want). Let me know if you have any questions, or need any help with the suspension work.
Frank, just saw that you replied to my question, thanks!...I just saw this...almost 2 months late...
I actually almost ended up the exact same route that you took with the plating. I talked to Consolidated Metal about doing my plating, and they agreed to do my small job, but the cost to do the post bake for such a small job drove the prices way too high. Jeff's Resurrections also painted my car and you guessed it, he also recommended TMF. I spoke to TMF, but they didn't do post bake treatments so I ended up sending my spring plates along with some hardware to Elephant Racing for the plating. Just got my last torsions bar in yesterday(back ordered) and got the rears almost buttoned back up tonight. Tomorrow, the car comes down and hopefully I've indexed the height correctly! What part of town are you located at? I'm located around Mopac and Anderson Ln. I'd like to take a look at your car!
Torque settings
Frank,
Can you tell me the torque settings for: 1. The pin in the front ball joint. and 2. The nut securing the top of the strut insert. Ive been reading through your post in relation to the front suspension, very informative and helpful. thanks in advance. Liam.
1984 3.2 cab india red 1970 1192 Volkswagen Beetle |
WOW !!!!! Such an impressively detailed build. Your page has me motivated and well informed . I'll be following a lot of your steps.
Talk about a thread resurrection.....
Robert Callaway PCA | Early S Registry | R Gruppe 1970 T Coupe, 1990 C2 Coupe, 2007 Cayman S 1962 S90 Coupe - Gone, but never forgotten... 1985 Targa - A distant memory... |
Control Group
No kidding
She was the kindest person I ever met |
LOL I was researching wooden chassis dollys and came across this page. There's a lot of info on this thread.
