colinsco's Avatar
Outboard CV/axle removal
Some time ago on this forum I dialogued with Early_S_Man and Grady Clay regarding a noise in my 88' Carrera's CV's (http://forums.pelicanparts.com/porsche-911-technical-forum/277538-how-do-i-know-my-88-carrera-cv-joints-worn.html#post2530625). Well, I am now taking the plunge and tonight removed the inboard flange bolts and even though it seems obvious I cannot find any confirmation of how to remove the outboard piece. Forgive a silly question but do I have to remove that nasty looking huge nut on the end of the axle (doh!) to get the entire assembly out? I have read the CV threads here many times and this is alluded to in one thread where the need for a 3/4" drive and a piece of pipe are mentioned. Hey, that's my car at Pacific Raceways this summer!
Old 01-14-2007, 06:43 PM
Don Plumley's Avatar
Yup - you need either an industrial strength impact wrench or a 3/4" drive socket and cheater bar to muster the 350+ ft-lbs to get it off.
Don Plumley
M235i
Old 01-14-2007, 07:11 PM
3.4 Bigger is better
88-diamondblue's Avatar
Colinsco
Yes the nut needs to come off and the lower shock bolt as well. Here are some pictures and how to do it. Carrera CV boot replacement
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 01-14-2007, 07:12 PM
