-   -   Short Shift kit installation (http://forums.pelicanparts.com/porsche-911-technical-forum/324867-short-shift-kit-installation.html)
toddu 01-14-2007 04:47 PM
So, I've got the shift housing put together. It's not back in the car, but I wanted to see how it felt. When moving it into the 5th gear position, it requires a lot of pressure (expected, a little more than before, but new springs). But, when coming out of 5th gear position, it seems to get a little hung up against the reverse lockout. Perhaps it will be different when back in the car (different leverage perspective). Anything to worry about? Should I file anything down a bit?
Thanks guys, this posting is so helpful for any project I attempt.
Todd
Oh Haha 01-14-2007 05:12 PM
Get it into the car and adjusted properly. You might find that you don't need to file anything.
What brand kit is it?
toddu 01-14-2007 06:00 PM
It's the factory kit. Just seems like the tab for 5th gear (the one the tab on the shift left runs along) might need to have to corner filed a bit because once the lever hits the reverse lockout, there just a hair more movement need to get it to clear that tab (in other words, the tab and the reverse lockout have it stuck in the 5th gear position). Like I said, I can eventually "force" it out, and maybe it will act different in the car.
Oh Haha 01-14-2007 06:20 PM
I understand. I would still install it first. There should be a more "spring" to it being new. I modified mine and had to go back and rebend the tab on the lever to correctly grab the tang on the shifter housing.
WPOZZZ 01-14-2007 06:20 PM
My factory ss was just installed last week and I had the same problem. After driving the car around this weekend, it seems as if the problem went away.
Pkaaso 01-14-2007 07:10 PM
I installed my factory kit and worked perfect after making the adjustments under the rear plate. Don't file or make any mods untill you install and adjust. I think will find it works right.
I don't have them handy but, there are a few real good threads explaining proper adjustments. Do a search and read before you do any un-reversable mods.
my $0.02
Paul
