OEM Headlamp
I recently purchased my first Porsche, these cars are simply amazing, been waiting 20 plus years and finally have one, wanna restore it to its former glory, first question is what were the original headlamps on the US 1979 930 Turbo
Old 02-02-2019, 07:53 AM
I am pretty sure yours would be correct for a 1979 US delivery car. Sugar scoops as they are called sealed beam light. The US was slow to adopt lighting that the rest of the world was using.
Old 02-02-2019, 08:33 AM
4flyboy's Avatar
H-4's please
Change over to the European H-4's with a relay kit, it'll will make your night driving a lot more palatable. Completely reversible if necessary......
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 02-02-2019, 09:56 AM
Thank you for the help
Old 02-02-2019, 11:34 AM
Has anyone tried the $50 headlight conversion kit. Seems like the quickest and easiest way to go.
Pelican 70476-m44
Old 02-02-2019, 11:51 AM
Old 02-02-2019, 12:00 PM
Formerly known as Syzygy
Canada Kev's Avatar
Originally Posted by DavidMn View Post
If you're looking for better lighting with original appearance, but without high cost, then this is the ticket, plus a headlight relay kit.
Kevin
Old 02-02-2019, 12:12 PM
Thanks, it was unclear if relay kit is needed.
Old 02-02-2019, 12:35 PM
Relay kit keeps the amperage of the headlights from going through the switch and stalk,also removes the length of wiring reduces voltage drop so they are brighter!
If you have sealed beams try the Hellas above^^^
Old 02-02-2019, 12:49 PM
Diss Member
Quicksilver's Avatar
More to the point: In the factory configuration the 120 watts of power for the headlights is routed through the headlight switch and the turn indicator/dimmer switch on the column. Over time switching all that current will make the switches fail and they are expensive. (Headlight switch $500, turn indicator $300!!!)
There is a headlight relay upgrade that changes it so only the minimal current needed to trigger the relay goes through the switches. This vastly increases the life of the switch plus the shorter current path means that there is less voltage drop across the wiring to the lights so it helps the brightness. (If you are running higher wattage bulbs the relays are kind of a requirement.)
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 02-02-2019, 04:15 PM
