Identification Of Material
I have found some kind of Putty Material Between the Fenders and the Body . It is a Gray Material
Can someone tell me what's this ? As you can see I have some rust Issues. Cordially Vic
Looks to be black strip (or ribbon) caulk/putty. More info...
fender installation putty.... From Jim Sims: "If you want the OEM material: The fender packing is also know as Terostat ribbon 2mm thick x 25mm wide, sold by the meter; the Porsche part number is 00004312900 or Pelican U-043-129-00. Pelican lists it for $27.75. When I ordered it from the Porsche parts system I recieved a roll which was significantly more than a meter in length; plenty to do a car maybe enough for two cars."
Warren & Ron, may you rest in Peace. |
See my post of a few minutes ago "rubbery material" - I think this might be the same gunk.
Brad Inventor of SNAPGAP - The Valve Adjustment Solution Patented in U.S. and Europe. Go to SNAPGAP.US or PM me. https://www.pelicanparts.com/More_Info/SNPVAK11146.htm?pn=SNP-VAK11146 |
Yes I Agree
Seam Tape Terostat Caulk/ Putty Thanks Vic ![]()
