-   -   window frame (http://forums.pelicanparts.com/porsche-911-technical-forum/32498-window-frame.html)
cookster 11-04-2000 02:16 PM
window frame
Can the window frames be lowered on a 79 SC The problem is that the front of the frame on the driver side door hits the roof pillar right before it bends into the roof. Thank you in advance
dean 11-04-2000 08:05 PM
I think you can adj. the frame a little bit. I the rest of the door adj. right?
Dean
Bobboloo 11-06-2000 05:52 PM
Yes, It is adjusted with allen wrench.There are several of them. Two behind the rubber dots (that are about the size of a penny) on the door where it meets the post. Three on the door where it meets the jamb (also behind rubber dots).Three inside the door.(2 at the bottom of the middle post and one behind the trim piece that runs along the top interior side of the door. I think thats it. It slides easily when they are all loosened.
Bobby
cookster 11-07-2000 06:19 PM
Thank You Bobby and Dean for the great news and instructions on how to lower the window frames. I can see what I'll be doing this week end. Thanks again
