Front fender flaring
Hello all,
I have a '75 911S and am looking for two replacement fenders for an upcoming paint job. Are the front fenders and flaring the same through all the years, 74-89? Thanks in advance, Randy |
Air Medal or two
as far as I think I know .. no. the turbo is diff as the RS and maybe others too
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between |
i've wondered this also. i think the swb (65-68) had a very minimal flare and the 69-89 i think were the the same, but i'm not sure. did the 911r have front flares that were basically the same as the 69-89 front?
BMW 128i 73 rsr clone - sold 68 912 project to become 911r (almost done!) |
Air Medal or two
Well there is the "ST " flare ,was it just the rear ? the 930 was both front and rear as the RSR and I know therte are others.so pick what you like. It is your flavor
Thanks for the replies. I believe the 930 turbo cars are different and probably the RS cars. The fenders that I've seen for sale here and on ebay and other sites often list the 74-89 model years. One thing that maybe different is the antenna hole. On my car it's on the left fender and I think on the later cars it may have moved to the right. Can anyone confirm this.
Randy |
Air Medal or two
I think the antenna hole will be the least of the problems......power to push big wheels is one,..... well it never stops..just gets slippery all the way dwn.
All solved with $$
driver fender hole is for manual antenna only.
passenger fender has more room and is electric antenna.. or used for manual
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Randy
you can use any 911 fender made from 74-89. The later the fender usually means less chance of rust, but that is not a guarantee ! The antenna hole can be filled if not on the side you want. But i would recommend installing a manual antenna on the passenger side if that is what you find.
1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race) |
Make My Day
+1, 74-89 911's all have same fender flare and will fit fine.
74 911S Targa ROW Building Designer/Business Owner |
I'll stretch it and claim that, while the front fenders are not the same, the fender flares from 69'-'89 are the same.
Sherwood |
