-   -   Ignition switch question.. (http://forums.pelicanparts.com/porsche-911-technical-forum/325411-ignition-switch-question.html)
TGTIW 01-17-2007 03:14 PM
Please forgive this if it's a newbie question, but I just want to be clean on the reason. Why is the 911 ignition switch on the left side of the steering column. I once heard that it was designed that way so when doing a "Le Mans start" the driver could start the car and put it in gear at the same time. Is that correct?
acapella8 01-17-2007 03:56 PM
Do a search on "left side ignition", I believe you will get more than enough replies to your question. Regards.
