Easy to put turbo engine in an 89C4
He guys, how easy do you think it would be to put a turbo engine in my C4?
My main concern is if the drivetrain can handle the power? Any thoughts?
1989 C4 Coupe 1975 911 carrera 2.7rs Sold 1978 911sc Sold 2001 Boxster S |
You'll be better off turbo'ing the 3.6 in there already! Just remove the pistons and have the crowns machined down to a more boost friendly compression ratio of 8.5:1 (this is done very often). You'll then have the advantage of twin plugs & EFI & AWD
![]() Your drivetrain will handle it... the G50 is a very strong box ![]() 964 pistons can be shaved down to within .100" of the deck. That gives you 8.5:1 c/r and has been perfect for turbo-charging. Even without going inside the engine, you can get 425-450HP at only 0.5-0.6bar
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Registered ConfUser
Re: Easy to put turbo engine in an 89C4
Re: Re: Easy to put turbo engine in an 89C4
Com'on guys. You are teasing me to no extent. Has anyone done this already? Should I pick up a blown c2 turbo motor, if possible, for the parts? Any info would be greatly appreciated.
C2T's run archaic CIS injection... you would need to back-date all your EFI in your 964 C4... If you don't believe me, contact Todd Knighton of Protomotive and have a chat with him (knighton@protomotive.com) about turbo conversions for your 964 C4
Which turbo set-up would work the best? I will search turbos to try to get an answer.
You need to speak to Mike Levitas... that chassis and drivetrain will handle plenty more power and he has the experience in doing it, everywhere from the street to the 24 hours of Daytona.
when you see hoof prints, dont automatically assume zebras |
Might be cheaper and more practical to sell your C4 and buy an earlier 930 if you want turbo.
Erwin '97 Boxster (sold), '67 911S (sold), '77 911 (sold) Definitive Australian/ New Zealand Porsche Resources |
I personally wouldn't go for anolder 930. You already have the awesome coil overs, ABS, power steering, AWD, working A/C and more comfort
I was suggesting an older 930 only if he didn't want to spend more money and used the money he got from selling the C4 - a 965 would cost a bit more I think.
Thanks for the input. I love the car, just want more umpf.
Try supercharging it.
The Unsettler
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
