Slumlord
Porsche_monkey's Avatar
Cabriolet Top Liner
The exterior of my '84 cab top is in good shape, but the interior lining is worn out. Material is flaking off and bits of fabric fly off when I drive the car.
Is there a solution other than a new top $$$ ?
I was thinking of removing the top and taking it to an automotive upholstery shop.
All economical suggestions welcome.
Old 01-17-2007, 07:24 AM
I'm not quite sure I understand. Do you mean the liner is old, or the inside lining of the exterior top is bad?
On my 86, I replaced the inside liner without removing the top.
Tim
1986 911 Cab
2008 Audi A6
Old 01-17-2007, 10:06 AM
Slumlord
I'll post a picture, sorry, I should have done that to begin with. I am vocabulary challenged.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 01-17-2007, 10:29 AM
I replaced mine also. I bought some semi stretch material and some spray fabric adhesive . Cut it a little larger than needed and you can tuck in the excess. Great results for under 10 dollars !
Old 01-17-2007, 11:39 AM
Slumlord
I was hoping to spend less.
84 Cab - sold!
Old 01-17-2007, 11:41 AM
MBruns for President
JeremyD's Avatar
Hey Harold - can you take a picture of that? I also have a "challenged" headliner
Old 01-17-2007, 03:17 PM
Yes I can ! although some pelicans may remember my first try at posting a pic of my cab ! I will try and post one tomorrow .
Old 01-17-2007, 03:52 PM
JeremyD , hopefully I have attached some pics of my diy headliner. The color is actually black . Certainly not perfect but way better than what was there ! I just kind of threw it up there. I am sure you could get much better results if you took your time . I also posted pics of rewrap of steering wheel ,I did take my time on that ! For 10 bucks I may try to improve on 1st halfassed attempt at headliner. Cheers
Old 01-18-2007, 10:37 AM
JeremyD's Avatar
If you need help - email them to me at jdixon1636 AT earthlink dot net and I'll help you post em...
Old 01-18-2007, 10:40 AM
#29 SCWDP (muhaahhh!!)
Gene Wilkes's Avatar
I had my headliner replaced this summer. The shop used some leftover material to make it and looks great! Any good upholstery shop should be able to do it!
IslandmanFL
SOLD...78 911SC (ROW) cabriolet/widebody
hear BEBE purr!!
92 325is
Now living in Sunny West Palm Beach FL!
Old 01-18-2007, 10:55 AM
Used Up User
imcarthur's Avatar
fwiw: Here's a pic of my inner part - minus the vinyl covered hard piece at the back.
Ian
'87 Carrera Cab
Old 01-18-2007, 11:09 AM
