-   -   oil pressure sending unit block and washers (http://forums.pelicanparts.com/porsche-911-technical-forum/325609-oil-pressure-sending-unit-block-washers.html)
redcoupe86 01-18-2007 05:19 PM
When I took the mounting block off the engine that the oil pressure sending unit attaches too it had aluminum washers on both sides. I didn't have alum. washers and I didn't want to use the old ones so I used some new coppers ones I had for the oil line bolt on the side of the engine that were the same size. I couldn't torque the bolt (with the hole that goes through the block) accurately b/c the torque wrench wouldn't fit down in there so I had to do it by feel.
Low and behold I have very small leak b/t the block and the engine. So I tryed tightening it again with a 7 or 8 inch wrench. I found I could still tighten the bolt (with the hole) some more (say 10 - 15 degrees) with just a bit of force. I didn't want to keep pressing my luck and strip the threads so I stoped there.
My question is can you use copper washers for this or do you have to use aluminum?
john walker's workshop 01-18-2007 06:29 PM
either will work fine.
redcoupe86 01-18-2007 07:00 PM
ok, good.
Do you have any recommendations on what kind of torque wrench to use to tighten the bolt, or is just snugging it up ok?
