Engine tool ???
I would like someone to please tell me what size the cam sprocket nut is. Or if anyone wanted to sell these tools they no longer need then......... Does Sears carry these? Something like a Crows foot. Also The oil line on the bottom of the case. It's a 1978 3.L This would be a nice tool to have also.
46mm for the cam's but you need the special crowfoot. there are no place in the left side for a closed one. You must also have excess to the cam end when timing the cams.
Find the tool here at Pelican parts. Roslin |
<a href="http://www.pelicanparts.com/cgi-bin/smart/S-mart.cgi?command=add&weight=0.65&itemid=PEL-TOL-P203&itemname=%34%36mm%20Crows%20Foot%2C%20%39%31% 31%20%28%31%39%36%35%2D%38%30%29&itemprice=59.50&i temquant=1">46mm Crows foot</a>
you can remove the nut with and impact wrench and a socket. And install the nut with the 46mm craw foot.
| All times are GMT -8. The time now is 02:20 PM. |
