How much is too much? (oil pressure)
Now that I've got the electrics sorted enough, I'm driving (yay) my new-to-me 73.5 911t (with what seems to be the original 2.4, about 70k miles). I'm trying to figure out what's what; this is my first Porsche.
One thing I notice is that the oil pressure can get quite high, especially while going up through the gears. Driving around town, it's in the 20-40 psi range, which doesn't bug me for 2500rpm. But pushing up towards redline with the oil warm (about 180) I see as much as 140 psi (upper end of gauge, but not pinned). Sometimes while cruising the freeway (3200rpm), I'll see the oil pressure hold around 60 or so, and sometimes it flutters up to 100+. I don't have any sense for what's "normal" on these cars. Is this? It seems like a pressure relief valve is sticking ... do I care? High oil pressure is wasted power, but I worry more about blowing off a fitting or filter. I'm careful to keep the revs low while the oil is cold. Thanks.
Chris Kantarjiev 73.5 911T Targa and the rest: 66 TR4A 69 FJ40 70 GT6+ 00 2.5RS |
Hell Belcho
sounds like maybe the sender isnt calibrated to the gauge?
On my Carrera, the gauge would peg to the top before it finally failed.
Saved by the buoyancy of citrus. |
Hell Belcho
sorry, the sender on the engine. I pulled it off one day trying to trace down the problem, and upon shaking it, there was something loose inside. I just bought a new one and popped it on. Good as new. I imagine it failed due to age.
On the earlier engines, i believe the sender is on the back of the engine near the transmission. On the later engines, it's on the right of the fan housing, connected to the oil line coming from the cam housing.
Ah. Replacing the sender sounds way easier than repairing the relief valve! Thanks. I'll try to find it next time I crawl under the car.
Hell Belcho
the sender isnt under the car. pop the lid and look to the right of the fan housing. You'll see a grenade looking thing connected to an oil line.
at least Im pretty sure its like that on a 2.4. It might be in the back of the engine on top
Senior Member
With the key on, disconnect the sender. Then touch the wire to ground. One of those things will make the gauge go to zero, and the other will peg it.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
But "near the transmission" makes me think closer to the front bumper ... is that front or back? I *do* know where the fan housing is, though!
Czar of C.R.A.P.
Rear of engine is where fan is. The tranny is connected to the front.
66 912 Coupe 84 Carrera Cab Hardtop HC3.4 Hyper Carrera 2005 Dodge Magnum 5.7 HEMI Cabriolet Racing And Performance C.R.A.P. Gruppe #1 Put on some C.R.A.P. and drive.... |
Hell Belcho
back of engine means towards the front of the car.
the fan is considered the front of the engine
Hell Belcho
lol.
I always considered the fan as the front of the engine
