'78 SC clock problem
Here's the situation: I don't know if it would be better to look for a replacement clock or try to fix the existing one, but here goes...
The second hand on the clock in my SC doesn't move. It ticks like it's working, but it doesn't actually move. Also, the clock frequently has to be adjusted to the right/current time, as it tends to fall behind a lot. Is this a simple DIY fix or should I be looking for a replacement? I'm new to 911 ownership and I noticed that 911 replacement parts are rather pricey, at least for my budget, so that's the reason I was asking if maybe I should try to repair it or get someone else to (since I have very limited DIY car repair knowledge but am eager to learn!) Any suggestions?
1978 911 SC coupe (whenever-I-get-to-the-lake driver) 2008 VW R32 #2846/5000 Past Rides: 1999 Jeep Cherokee Sport-lifted |
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers). '83 SC Coupe SOLD '96 Carrera 4 Coupe SOLD '89 Carrera Targa SOLD |
If you want to have a go at attempting to diagnose the problem, read through this thread.
It sounds to me like your issue is mechanical, such as a partially stripped gear. You might be able to find a clock for donor parts at a swap meet for $5 to $20. There are experts like North Hollywood Speedometer that will also repair your clock. Good luck. There are ways to make them tock! Brian |
More...the search function is your friend...
http://www.pelicanparts.com/techarticles/mult_vdo_clock_repair/mult_vdo_clock_repair.htm http://www.pelicanparts.com/techarticles/mult_vdo_clock_repair/mult_vdo_clock_repair2.htm Clock Fault Clock repair Dash clock repair VDO Clock Crystal Info? Cheers, Paul.
My clock's sweep second hand does not move unless you set it because it is an elapsed time marker. (the white hand)
78SC coupe, Silver Metallic |
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
porsche911girl,
As oneblueeyedog notes, the white hand isn't a second hand, but reather an adjustable marker hand. You can set it to the position of the minute or hour hand to mark a beginning of a time you wish to measure, such as the elapsed time for a journey. You'll note that twisting the small knob in the center moves it and twisting the same knob while also pushing it in, moves the clock hands. Cheers, JR
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle |
