sc wont start
hello ladies and gents,
I am a complete novice at mechanical stuff, my 81 sc will not run. i know it has a spark and I know it has fuel getting to the cylinders but it just will not go. What do i need to check?
Gordon
Old 01-20-2007, 09:21 AM
Student of the obvious
LeeH's Avatar
When's the last time it ran? How well? Did it just stop, or did it not start after some work? Where are you?
Lee
Old 01-20-2007, 09:23 AM
sorry, it was off road for a while getting sprayed after some little B***ard scratched it, wouldnt start at paint shop.ran like a bag of spanners about a month ago, ran for a bout 2 seconds yesterday (like a big bag of spanners) now doesnt even sound like it will start, this all began about a year agoafter the cdi gave up the ghost. so I fitted an msd, whilst this was being done had ssi's fitted, hasnt really run properly since, now i keep getting jolts from the plug wires, tried a new set no difference, new rotor new cap, same but plugs out and connected, all firing with a bright white /blue spark, that much petrol going thru it was at one point leaking from the ssis ! oops! Am stuck now.
Gordon
Oh am in Dorset uk.
Old 01-20-2007, 09:31 AM
Early_S_Man's Avatar
Porsche Crest
Gordon,
Sounds like it was running rough ... when running. May have had an airbox explosion/backfire??? Did/do you have an airbox pressure relief valve [flapper] fitted?
If the airbox has cracks in from a backfire or explosion ... it would have the symptoms you describe.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 01-20-2007, 11:35 AM
yep it has a pop off, could this be vacuum leaks? thing is now it just wont fire at all. has a spark has fuel wont do anything !
Gordon
Old 01-20-2007, 11:44 AM
