pedal cluster removal
Hi, In order to remove the pedal cluster do you have to lift the front of the car to remove the skid plate to access any bolts or nuts that secure the cluster or is removal of nuts strictly from inside the car? The car is a 77 911. Thanks Jerry
Old 01-24-2007, 06:06 PM
PhatA55's Avatar
My 1979 930 required lifting the front to remove the belly pan. This allows access to the two nuts/bolts (I can't remember which now) that hold the front of the cluster to the body.
--Mark--
1979 RoW 930
1999 BMW Z3
Originally posted by randywebb
It is the people who have some kind of psychological problem and use the car (or some hierarchy they set up involving the cars) to try to elevate their personal sense of self-worth that irks me. I feel sorry for them of course, but they are difficult to put up with.
Old 01-24-2007, 06:10 PM
also, leave the brake rod attached to the pedal and the flat bar bolted to the side of the cluster. just remove the top bolt for the flat bar on the side of the upper aluminum housing and pull the top clip[ and pin for the brake rod. way less screwing around that way.
206 637 4071
Old 01-24-2007, 06:39 PM
Thanks for the replies, One reason I am asking is that I currently have the rear of car jacked up and supported to do some rear susp work. I plan to rebuild my pedal cluster this winter and replace the clutch cable also. I know I needed to have the rear lifted to replace the clutch cable so now I know I need to raise the front to remove the belly pan and remove the bolts/nuts. Correct? Also, after replacing the MC last winter I can see that it would be easier to remove the brace from the MC housing than from the cluster. Any other helpful hints for this job? Thanks again Jerry
Old 01-24-2007, 07:08 PM
JTL JTL is offline
JTL's Avatar
Arrow
You can access the pedal cluster bolts without lifting the car. All you do is reach in with your left arm and a ratchet. The belly pan has to be removed first though.
The clutch cable job is easy. The rear of the car does have to be lifted. What's wrong with the cable? The cable travel should be about 25mm at the trans. If you are getting less the problem could also be a broken pedal cluster shear pin.
BTW, shear pins of the correct size can be purchased at ACE for 25 cents or so.
jt
-84 targa
Old 01-25-2007, 06:28 AM
