rpmillie
Guest
Posts: n/a
Cooling tin...which way to install on SC?
I have an 80 SC that I recently rebuilt and installed. It is running warmer that I had hoped for and am not sure if I installed the cooling tin correctly. These have the cutouts and I believe they should be installed in a certain direction.
Which way do the cutouts face...towards the crankcase or towards the heads? How much difference would it make if they are installed incorrectly?
Thanks.
Ron Milliet
Old 11-13-2000, 06:16 PM
Early_S_Man
Guest
Posts: n/a
Per Bruce Anderson's Handbook, second edition, p. 176 ... the cutouts are nearer the heads.
Warren Hall
1973 911S Targa
Old 11-13-2000, 09:30 PM
rpmillie
Guest
Posts: n/a
Thanks Warren. I am relatively certain I installed them the same direction as the end pieces which would be towards the crankcase. If I remember correctly...the end pieces must face the crank...no real way to mess them up. I will verify tonight.
Old 11-14-2000, 06:33 AM
