Pedal cluster rebuild find - now what?
Got the pedals out and started cleaning up the area under them. The had been a previous brake fluid leak that had pretty much killed the paint in the area. Found this crack, cut, split really don't know what to call it. It was under some putty that came up with the cluster. Is this normal and if not what should I do about it?
http://forums.pelicanparts.com/uploa...1169349477.jpg http://forums.pelicanparts.com/uploa...1169349501.jpg |
Thats normal. There are a number of those in the floor, they are used by the factory to drain the body when it goes through a number of baths prior to painting
Yep, that's it. Prep it, prime it and paint it. A pretty good match out of the can is from NAPA. It's called GM low gloss black engine paint. Easy fix.
Thanks guys. Nice to find something normal for a change.
| All times are GMT -8. The time now is 02:42 PM. |
