Guest
Posts: n/a
Storage for the Winter
Living in Minnesota and storing my 84 911 in my garage for the Winter. Any suggestions? I've heard that "just disconnect the battery and you're fine". Any other tips?
------------------ karptj |
Guest
Posts: n/a
Fill up the gas tank, trickle charger on battery,I'd take it out.Run it w/ clean oil before you store it,Xtra air in tires to avoid flat spots. I'd also put something over the tail pipe to keep out the rodents or..., perhaps a tennis ball.Cover?
Guest
Posts: n/a
Check out my response to jfaisten. Complete job for storage
Guest
Posts: n/a
I have been told by many people it is very important to put a plastic sheet or tarp under the car. This will help with moisture coming from out of the ground and attacking the bottom of your car.
Guest
Posts: n/a
Excellent. Thank. tj
