Guest
Posts: n/a
Swepco
I've read a couple of postings talking about Swepco. I am assuming this is some sort of transmission additive? If so what are the benefits and where do you get it?
Guest
Posts: n/a
It's actualy a brand name of lubricant. It appears that the best place (read cheapest) to get it is Zimms. I thought I had the web adress but I tried the link and it didn't appear to be right.
[This message has been edited by mackgoo (edited 11-10-2000).] [This message has been edited by mackgoo (edited 11-10-2000).] |
Guest
Posts: n/a
Swepco 201 is premium industrial gear lube. Pretty blue color and smelly. You can order right here from Pelican or Vertex. About 40 bucks a gallon. Drain and fill your tranny with a cheap gear lube and run it to flush it out while you wait for the swepco to come in. Then drain again and install the good stuff.
Guest
Posts: n/a
Guest
Posts: n/a
Pelican Parts (where you are now) sells it for $37.50. $2.46 more than the before mentioned site. It may even be cheaper or same with shipping involved.
I personally like to try to support our host!
Guest
Posts: n/a
Windward Performance has been selling Swepco for a couple of months in Panorama for $29!! www.windward-perf.com or 800 642-1348
Charlie '87 Carrera |
Guest
Posts: n/a
Charlie ...I just received mine from Windward...by the time all was said and done it cost me about 42 bucks with shipping and handling. Guess shipping to CA does cost quite a bit from Vermont!!!! Gonna put the stuff in later today...did the drain and cheap lube for a week while waiting.
------------------ Howie 79SC |
Guest
Posts: n/a
Yeah, the shipping is a shocker. Must be considered hazardous material. Shipping alone on mine was $11.00.
Guest
Posts: n/a
Please be aware that there are four different grades of Swepco 201 ... the 'blue' most suppliers are selling is the SAE 80W-90. I recall the 'straight' SAE 90 I used to get from Garretson Enterprises was just golden brown, or there was no color coding back in the '80's! Swepco 201 is also available in SAE 140 and SAE 250.
------------------ Warren Hall 1973 911S Targa |
Guest
Posts: n/a
I'm using the Swepco 210 (80W-140) which is red.
------------------ Jack Olsen 1973 911 T sunroof coupe |
Guest
Posts: n/a
I also noticed that our host sells the Swepco at a reasonable price compared to at least one anonymous (Automotion) overpriced parts house. Indeed, I am making my order list now and finding that Pelican is quite competitive.
But what's up with those $18 non-limiter SC distributor rotors? ------------------ '83 SC |
Guest
Posts: n/a
Actually the swepco 203 is the best for track purposes, 201 is better for everyday use. Carquip Inc. carries both.
Guest
Posts: n/a
Does anyone know of a vendor that carries the 212? I've got a highly overburdened 915.
------------------ Jack Olsen 1973 911 T (3.6) sunroof coupe |
