Anyone installed the Weltmeister jack pad/tow hook?
It looks like I have to move an oil line to make it work. Anyone done this install and come across this? Car is an 82sc.
Sean
1982 SC D-Stock #372
NASA GTS2
1971T restoration in progress, read about it here:
http://911restorationmadness.blogspot.com/
Old 12-29-2006, 11:54 AM
Nape75'911T's Avatar
Bump
+1
OK, I have this car, now things are out of control !!!!
83 930 Turbo....the car I have always wanted!!
K27 7200, Tial 46mm WG with straight pipe, Fabspeed Exhaust,B&B halfbay IC, Wevo mounts, Rennline floorboards, Rennline goodies, Optima mount, Elephant finned oil lines, widemouth cooler, high speed fan.
Old 12-29-2006, 05:00 PM
i would like to get one of those and would also like to know. mine is also an 82sc
Old 12-29-2006, 05:11 PM
I've got one on order for an 87 cabriolet. Don't mean to highjack.
87 Carrera Cab GP White
01 740i Sport
03 Honda Odyssey
Old 12-30-2006, 09:15 AM
Sean.....
if nobody posts the answer and pics, I wil let you know as soon as mine arrives, it was shipped by our host on Friday......I have my rear bumper and muffler off anyway for other projects, so I will take some pics, and post them.....
Mark
Old 12-30-2006, 09:36 AM
Thanks Mark. I've got one and went to install it and I can't see any way to make it work without having to move the oil line. Curious what others have done.
Sean
NASA GTS2
Old 12-30-2006, 10:14 AM
Zeke's Avatar
Recent thread on this...
Old 12-30-2006, 10:32 AM
there was a recent thread, but it didn't resolve the issue of the oil line
Sean
NASA GTS2
Old 12-31-2006, 06:33 AM
Nevermind, it won't work. I spent some time with it today and I couldn't find a way around the oil line. It's going back.
Sean
NASA GTS2
Old 12-31-2006, 01:01 PM
Zeke's Avatar
Ah, well that is too bad. And, it's too bad the thing doesn't work with the later cars. I like the concept. Another reason to get SSI's, I guess.
Old 12-31-2006, 01:27 PM
how much would the line have to move t clear the pad?
Old 01-02-2007, 02:41 PM
It would need to move down towards the ground quite a bit (1-2 inches). I'm not going to try it for fear of putting stress on the connection points of the line. Time to try something else for me.
Sean
NASA GTS2
Old 01-02-2007, 02:59 PM
Sean, mine arrived last night....
and you are right.....I only briefly ran out to the garage, as I got home very late, but it will not fit easily. Also looks like the line from the Turbo oil return and drip pan may interfere a little......PITA.
I have purchased a TON of stuff from our host, with ZERO issues, but I wish this was properly explained on the page, so I could have saved myself the grief. I won't return ship it from Toronto, not worth the cost.....so now I will try to sell it if all else fails.....
Great idea, and it would have been slick if it fit my car.....I will see if I can modify it before I give up, at least I have a full time mechanic and a damn good welder working for me.....so there may be hope yet.
Cheers.
Old 01-10-2007, 11:19 AM
I'm a little annoyed as well that it is sold claiming to fit our cars. I was actually thinking about having something fabricated. There just aren't a lot of good options for our cars if you retain the stock bumper. It's an interesting attachement point so if you could fab something to run over the oil line it might work.
Sean
NASA GTS2
Old 01-10-2007, 11:47 AM
That's what I am thinking.....
.....like keeping 75% of it as a template, and re-engineering the lower part that interferes with the oil line, then cutting off that piece and welding up the new modified part, or having a new part made from the template.......I would love the convenience of that jack point to lift quickly, so I can throw jackstands under the rear end......
I will let you know if I make something....and post pics.
Old 01-10-2007, 12:27 PM
can you please post some up close pics of it before you modify it also. i want to see how its made and attatches so i can make one that fits thanks
Old 01-21-2007, 06:13 PM
