915 tranny identification
I have done a extensive search and cant seem to find the identification info for the 915 trannys. There are a couple posts of scanned papers with the gearing info for the 901,902,905,911 trannys but I cant find them for the 915 trannys. If anyone has anything could you please post it. thanks.
brian
*NEW 1969 911t targa soft window option
1967 912 Targa Soft Window
1989 911 GP White Cabriolet
1970 911t
2001 Chevy Silverado 1500
1997 Audi A4 Quattro 2.8
2003 Acura TL Type S
1973 911t 3.0 track car (SOLD)
Old 01-21-2007, 09:20 AM
1970 911t
Old 01-21-2007, 05:38 PM
Do you have the tranny type numbers ie 915/06 or 915/73
These happen to be 1974 and 1986 915 5 speed's respectively. There are a lot of different ID's between those years. Also serial number will help narrow it down for you.
I do not have a source for the gear ratio's per year, but a bit more info would yield better feedback from the board IMO.
Tony G
2000 Boxster S
Old 01-21-2007, 06:42 PM
here are the two i am looking at.
915/12 #722087
915/?? #716467
Where is a good reference for this information? I flipped thru bruce A's book found a lot of info on engines but not much on trannys.
thanks guys.
1970 911t
Old 01-21-2007, 06:47 PM
The 915/12's are the first 915's made between 1971 and 1973. The reference I have is a sheet from Stoddards called 911 Body and Engine I.D.
There are no tranny serial numbers for pre-74 that I can find and the 74's start at 724xxxx for the 4 speed and 734xxxx for the 5 speed.
Hope that helps.
Tony G
2000 Boxster S
Old 01-21-2007, 07:03 PM
do you know if the early trannys are mag or alum cases?
thanks.
1970 911t
Old 01-21-2007, 07:12 PM
