-   -   Inconclusive alternator testing (http://forums.pelicanparts.com/porsche-911-technical-forum/326444-inconclusive-alternator-testing.html)
defcon65 01-23-2007 08:57 AM
I pulled the alt and took it to a local shop where it tested out at 14.5V. Guy says the voltage regulator is OK and he is replacing the brushes for $20, so it's back to square one on why the battery seems to be overcharging....
Is there anything else they should be looking for? Battery load tests just fine, holds charge at about 12.7V.
What else makes the tach jumpy?
Regards,
kach22i 01-23-2007 09:39 AM
I've read about false positive and false negative testing of the electrical systems before including the alternator and voltage regulator.
Do a "search" and see what comes up.
EDIT:
The shop that rebuilt mine (Southfield, Michigan) had an article on the wall, don't know if this link will tell you anything.
http://www.aeimich.com/
averyhabbott 07-23-2007 06:51 AM
http://forums.pelicanparts.com/porsche-911-technical-forum/348937-voltage-too-high.html#post3392535
Same problem you were having. Have you solved yours?
If so, what was the solution?
Early_S_Man 07-23-2007 08:34 AM
Bad points can make a tach jumpy.
The Voltage regulator is the ONLY part that can make the battery getting overcharged!
