81'SC hot restart problem
upon restarting my warm engine after aprox 10 minutes, it will start just fine, but upon applying throttle, it will die. If I let it run at idle for a minute or so, it clears out and everything is ok. do you think I am loosing residual pressure? I checked all fuel pressures a while back and all seems ok, it held pressure to spec. Any ideas guys? p.s. have all NEW injectors
| All times are GMT -8. The time now is 10:56 AM. |
