Coupe vs. targa roll bar
I bought a roll bar from a member here on the list. I was told it was for a coupe and it turns out to be one for a targa. In doing some research, the only company that seems to differentiate between targas and coupes is Safety Devices (the type I bought). Aside from the obvious roof differences are the coupes and targas that different dimensionaly? The bar needs to have some mounting tabs welded onto the longitudinal members for the front feet and looks to need the same for the rear legs. From the Stable Energies website it looks like the rear legs on a coupe specific bar use through bolts into the inner fender wells. The targa looks to need mounting plates welded on the back somewhere. Does anyone have any pictures of a Safety Devices bar bounted in a targa? Are the inner fenders different on a coupe and a targa? I think the rear seats are the same for both? Am I going way too far down the wrong road? Thanks for your thoughts.
Joe
1973 911 RS replica, Irish Green 1972 BMW 2002 1968 BMW 1600 1965 Triumph TR4A 1961 Land Rover Series 2 88 |
Safety Device Roll Cage for Targa....
I have some pictures of a SD roll cage used on Targa (SC) and the mounting bases welded on.
![]() ![]() ![]() Hope this will be of help to you. Good luck..... TD |
Thanks TD. This board is amazing. Now to figure out if the wheel well dimensions and roof width's are the same. I wonder if Safety Devices moved the mounts for any particular reason?
