easiest way to convert 3 to 5 gauges
my 912 has 3 gauges, how difficult would it be to add the other two (one is a clock I believe). I assume there would be a need to cut the dash as well. Are the early gauges expensive, haven't seen many for sale?
would a 74 dash/gauges fit?
I actually wanted the 3 guage. I wouldn't use a clock, nor do they usually operate correctly and whatever that other guage is I doubt I need. Tach, speedo and temp/fuel and I am ready to rock. I personally thought less was more.
I don't think I'd want a street 911 with less than 4 gauges. Starting from the left on a standard 5 gauge dash you have the fuel gauge / oil level gauge. I could see going without the oil level gauge but since it's a combo gauge why not have it. I definitely would want a fuel gauge in a frequently driven car. The next gauge to the right is the oil temp / pressure gauge. I wouldn't want to go without it. The next two, the tach and speedo, then finally the clock. The clock you could skip for sure but the one in my '65 still works well and the clock in my SC actually keeps better time than my laptop.
the weird thing is the left gauge i believe has oil temp, oil press and fuel level, so the only difference is with 5 gauges you get the clock and oil level. I just personally like the 5 gauge look on the older pcars
ooh, please don't cut a 66.
I was actually thinking of a taking a 3 whole dash I have and putting it in my 911 track car I am making. I like the simplicity of the 3. Would you have interest in the 5 pod dash I will be removing?
brian |
its going to take me atleast a few days to cut them out of there respective cars. are you in a huge hurry?
Mile,
I will second “ ooh, please don't cut a 66.” A good solution is to build a 3-segment combination instrument like the 914-6 guys do. Fuel level, oil pressure, oil temperature and just use he dip-stick for the oil level (better anyway). Best, Grady |
Come to think of it..I'll bet North Hollywood can make you up a set of custom multi function gauges to drop into the 3 openings
All this cutting and welding of a 66 makes me nervous. I too have a 912 converted to 911 but I have three guages. Poping in a six is only a conversion that will always be a plus, its not like slant noses or whale tails. However the three to five will rest on your mechanical ability so make sure its up there if you start cutting, you only get one chance.
When I think of conversions, and non period correctnes, I often think in terms of reversibility. In other words, if you wanted to convert back to a 912, you might just unbolt the 6 and bolt in the 4, basically. But wehn you get the grinder out, and the torch, things get a little messier.
Of course, its your car, so have fun. BTW, I LOVE my clock...it keeps fine time, and the clicking when I sit in the car and the engines off is charming. I wouldn't change it! (I might addd avolt guage to it though...) |
Has anyone out there added two gauges to a 3 gauge dash? Accurate cutting of a hole xan be done with care. Isn’t there a flange on the inside that supports the gauge?
Wow, talk about a wayback machine!!! This thread is over 10 years old!!!!
Like the others said you could do a triple gauge and use a 930 tach and put either the fuel of volt-gauge in there, in addition to your speedo. That way you'd have 6 gauges in 3 pods.
The car is a six cylinder. The 3 gauge pod was drilled and two smaller, uglier gauges were added. The best course is to correct the PO’s handiwork and add the proper VDO gauges.
Still hoping someone has done this before and have some advice. |
Here is some background on the car. It is a 912 tub with a replaced left fender and 911T rear deck lid. It has. 2.7l motor with a hotter cam, MSD, and Weber 40s. It has mangled wiring. Lastely the PO added two after market gauges on the 3 gauge pod. It doesn’t look right. It is a frankencar.
Seattle Speedo is restoring a 5 gauge set that I intend to install. Question is: has anyone converted from 3 to 5 gauges? I think the stock pod has a flange that supports the gauge. I’m concerned the gauge will droop or fall out. Any ideas? http://forums.pelicanparts.com/uploa...1541259741.jpg http://forums.pelicanparts.com/uploa...1541259741.jpg |
Nice combo gauge. I’m getting a 5 gauge set restored. A volt meter and oil presure gauge will be added to the fuel level and temp gauges. My plan is to remove the mismatched and too small gauges and replace them with a mathcing set.
I guess if you were determined and had some metal fabrication skills anything could be done. I think the easiest way would be to find a donor dash that could be welding in at the factory seams.
I would consider keeping it three gauge and just repair the areas under the two added gauges. |
It appears there is a bracket on the back of the gauges. I can fab a couple up for the new gauges. Shouldn’t be too tough.
http://forums.pelicanparts.com/uploa...1541384388.jpg |
Gauges up to '69 had the studs to allow the brackets. Newer gauges only mount with the rubber seal.
| All times are GMT -8. The time now is 07:37 AM. |
