Help with tire selection
I am looking into new tires and budgeting for some 2007 items. Currently I am running Yokohama AVS100 205/60 on 15X7 on all four corners. I would like to shorten the sidewall to get less flex but I am thinking the 205/50 series on 15's would shorten the overall height to much, just about an inch. I know it would effectively shorten my gearing also, but to what extent? I was also thinking about finding some 16x7 fuchs or other wheel to run for my track events and then run 205/50 on 16's which would keep my height about where it is now, give me the lower sidewall but cost more and possible create more rotating mass. Since I am running stock brakes on my 71 I don't know if more mass is a good thing. Tire selection would be greater I think in the 16" wheel size also. I am leaning towards Toyo RA1's and if I had them on separate wheels I could extend their life.
Car is set up street/track with the following 20F T.B.'s 26R T.B.'s 21mm adjustable front sway 19mm rear sway alignment by TRE with -1.5 deg in front & close to -3 deg rear, lowered to euro height. Weight is about 2150lb with a 1/2 tank of gas. Car is used on weekends and will see about 12 DE/track days in 07. Thoughts, recommendations or criticism is welcome. TIA
Dan Byers |
I like this site for tire size comparison.
http://www.miata.net/garage/tirecalc.html Beyond that, I'm not sure I can be of much help.
Roger 1968 sand beige 911 Normale coupe #11830091 1984 metallic moss green with champagne interior 911 Carrera coupe 2012 silver with red interior Boxster |
Large Registered Member
Hey Dan~
You're welcome to try my 6&7x16's for a day at the track... I've got Falken 451's mounted on them that should be fairly equal to the AVS100's... They probably have a couple of track days left on them... They're just sitting as spares for now, as I'm lovin' my new 8&9's!!
'85 Carrera Coupe, Marble Grey #118 JP/R6 '93 Lexus SC400, '00 Ford F-150 '70 911T- 2.7 (SOLD) |
I have 15 inch Fuchs on my '87 Carrera 3.2. I bought a set of 4 Pirelli P6000 from Tire Rack. Front are 195x65x15; Rear are 215x60x15. $543.82 total delivered to Zionsville, IN - just outside of Indy. Although these tires are tall, I feel no squirm. Then again, I don't track the car.
1987 Carrera 3.2 |
PRO Motorsports
Dan I'm running 205/55/15 front and 225/50/15 in back on 15X7" Fuchs on Tangerina.
They are the BFG G-Force Sport. But you can do better tire wise.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
Tyson, (sorry for the hijack)
What sort of camber settings are you running on the rear to get 225/50's on 15x7's in the rear? I've seen this setup before and would like to try it on my '72T. As luck would have it, I have a stack of good 225/50 RA-1's left over from my E30 track days. ![]() Thanks, Jim |
Thanks for the help guys.
Patrick, what series tire are those on the 6 and 7's? I might take you up on that. Tyson, I feel to get a 225/50 under the rear I would need some "evil" done to the rear control arms like you explained in the other thread. The 205/60 actually pearls on the passenger side rear on hard lefts during track days. The 225 would give me a wider patch but would be also wider overall. Since Ingo is out of country, I may go by his place and "borrow " his 16's while hes not looking to play with.
Dan Byers |
I like the Toyo Proxies T1-R's. They come in a good range of sizes as well.
Take a look here - http://www.tires-easy.com/start.html
1971 Targa RS - Sold 1964 BMW 1800Ti 1969 BMW 2002 |
![]() ![]() You put those on, and I'll never keep up with you!!
Designer King
I used to have the same tires and sizes as sig_a. I switched to 205/50/16s on 7s all around for street use. The squirm a lot less yet have about the same ride quality. The tires are Fuzion ZRi. I am very happy with them.
BTW if you go from 205/60/15 to 205/50/16 your speed will read about 2.5% higher than before @ the same speed.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
PRO Motorsports
The fender lips are not rolled. The car is too original and still has the textured finish on the lips, so I don't want to disturb that. I've had absolutely no rubbing issues with it. But then, tire sizes and dimensions vary greatly from brand and model, so sometimes the stated size isn't always on the money. And every car is a little different too!
