Anyone make a plastic 11 blade fan?
I wouldn't mind having a lighter plastic 11 blade fan. Is that an option?
Old 01-29-2007, 01:47 PM
PRO Motorsports
Tyson Schmidt's Avatar
I wonder if it would stand up to the pressure. That fan moves a TON of air. And there is a lot of resistance on the other side. I've seen engine shrouds that were missing a few bolts in the rerar, and the shoud flexed a good 3 inches off the motor when revved.
The mag fan is plenty light, IMO.
If you really want to save weight here, I've found the later carrera alternators are significantly heavier than the early ones. That's also some rotating mass too.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 01-29-2007, 02:05 PM
Early_S_Man's Avatar
Porsche Crest
Porsche has always used FRP fans [fiberglass-reinforced plastic] in horizontal applications for racing engines since the days of the 771 engine ... but, I suspect that long-term durability was never a concern. Looks neat, though, in the engine pics of RS61s, 804s, 907s, 917s, and 935s.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 01-29-2007, 02:15 PM
I would think something with Kevlar reinforcement, or possibly carbon fiber with a strong weave would be up to the task even at higher revs, but the cost to accurately produce a part like that would be astronomical!
Michael
Sans Porsche...for now
2009 Mazdaspeed 3 Grand Touring daily driver / DS autocross toy
2010 Subaru Forester X Limited - wife's daily driver
Old 01-29-2007, 05:02 PM
Most new cars have plastic fans. No kevlar or carbon fiber involved.
Old 01-29-2007, 06:25 PM
Fair and Balanced
Rearden's Avatar
Yes, but a plastic fan attached to a radiator or oil cooler is not in the same league as a 911 fan sucking air into the dark recesses of the motor.
Old 01-29-2007, 06:31 PM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
Call up PMNA and get your hands on an IMSA 962 fan in carbon kevlar. I saw a setup like that not too long ago at PMNA. I believe the housing is also a bit smaller than normal as well.
74 911s neverending story. two feet and a jetta for now.
Old 01-29-2007, 06:35 PM
I spoke to a friend in the plastic injection molding business about this application. He said it could be done but the mold and low volume production would be very expensive.
Warren & Ron, may you rest in Peace.
Old 01-29-2007, 08:30 PM
IROC's Avatar
No doubt. I just replaced the alternator in the '88 3.2 in my car and it was as if I was mounting a shot put back there. Very heavy.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 01-30-2007, 04:50 AM
David's Avatar
Carbon fiber would be nice. With the lower weight, imbalance wouldn't be as much of an issue so maybe balancing wouldn't be required.
Old 01-30-2007, 07:30 AM
