unbalanced wheel lock up
I recently installed all new rotors and brakes on a 86 cab. The problem is the front right grabs earlier than the front left giving me premature lock up on the right side . I was wondering if there is a proportioning valve any ideas ?
1986 blk 930
2000 expedition
2000 bmw 3 series convertable
1996 Silverton 312 sedan bridge
Old 01-25-2007, 01:38 PM
Goth's Avatar
It is common to have old brake hoses cause this after a brake job. Inside of hose starts restricting fluid flow.
Doug
84 Carrera Coupe - Black (the Goth look)
The more I learn, the more I realize I don't know
Old 01-25-2007, 02:00 PM
coloradoporsche's Avatar
Did you bleed the brakes? If not, this would be the first step. If it does not fix the problem, do it again
Sheena is a punk rocker
Suzy Is A Headbanger
Heidi Is A Headcase
Judy Is A Punk
The Ramones' earliest titles included 'I Don't Wanna Walk Around with You,' 'I Don't Wanna Go Down to the Basement,' and 'I Don't Wanna Get Involved with You.' Dee Dee later said, "We didn't write a positive song until 'Now I Wanna Sniff Some Glue'."
Old 01-25-2007, 02:21 PM
All new stainless lines complete bleed down and used the blue high performance fluid.
1986 blk 930
2000 expedition
Old 01-25-2007, 02:22 PM
This is what they look like
1986 blk 930
2000 expedition
Old 01-25-2007, 02:27 PM
Hell Belcho
Nostril Cheese's Avatar
sticking piston?
Old 01-25-2007, 02:45 PM
I lift the car and the wheels spin free hit the brakes and release no problem . The front right just locks up a tad earlier then the rest. I mean this is hard braking not just tapping the brakes . I run goodyear f1 245-40-17's all new so it's not the tires
1986 blk 930
2000 expedition
Old 01-25-2007, 02:56 PM
River Rat
Dave 86 930 Fl's Avatar
Steven,
I'm having a similar problem with my 86 930. I've ordered rebuild kits from Pelican for both front calipers, hopefully this will resolve the problem. I'll follow up after the parts arrive and I've done the rebuild.
Regards, Dave
1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs.
Old 01-25-2007, 05:29 PM
madmmac's Avatar
Double check tire pressures....drive the car for a while and rebleed the brakes.
If still a problem, go for an alignment and corner balance.
madmmac AKA Mitch
1984 Factory Turbo Look
2006 4Runner
1998 TRD Supercharged 4Runner (Sleeper)
Old 01-25-2007, 06:04 PM
mine does this as well. i blame it on uneven pavement traction side to side in most situations but sometimes it apears as if they should lock up at the same time
Old 01-25-2007, 06:07 PM
Registered Cruiser
jorian's Avatar
I think the proportioning valve only controls front to rear bias. My left front wheel locks up sooner than the right and I believe it is the caliper. I have rebuild kits waiting to be installed.
87' Carmine Red Carrera - Keeper
82' Silver SC - Sold 79' Gran Prix White SC - Sold
05' Black C2S - Daily driver
I have never really completely understood anything.
Old 01-25-2007, 06:13 PM
Re: unbalanced wheel lock up
There is a proportioning valve between the front and rear calipers, not side-to-side.
Did you bed the pads before? If you didn't, could be different coefficients of friction between wheels.
Sherwood
Old 01-25-2007, 08:28 PM
The calipers are new as well , I think tire pressure and corner balance may be the issue . I did heat cycle the pads but maybe it's just a quirk .
1986 blk 930
2000 expedition
Old 01-26-2007, 03:59 AM
Usually a corner balance will help. You'll probably find that the wheel that locks up first is carrying less weight than the other one on that axle. With a driver in the car, to get the front wheel weights eqaul, you usually have to accept too much weight on the left rear wheel.
Either that, or carry a heavy passenger with you at all times.
JR
We need not be gracious when our enemy dies. Civility is only afforded those who don't go to their grave trying to destroy us and ours. E. M. Burlingame
Old 01-26-2007, 04:35 AM
Slippery Slope Victim
NY65912's Avatar
Ditto on the corner balance, it did a world of good on my SC with 930 brakes. I was having a hell of a time with front lock up.
MikeČ
1985 M491
Old 01-26-2007, 05:19 AM
Somatic Negative Optimist
Gunter's Avatar
I found at times that the calipers are not centered on the rotors and require shimming.
With pads removed, look down and check that there is equal distance/space between rotor and caliper.
It's something that is normally not checked when new rotors and calipers are installed.
It can be out quite a bit. I have seen more than 1/8" discrepancy at times.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 01-26-2007, 08:28 AM
