Lug nut specs?
What are the specs on the lug nuts for a 87 Carrera? Size?
The info that I will need at the parts store. Thanks |
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_MISCLL_pg13.htm#item64
You most likely have 999-182-003-36-M260 |
Normal parts stores won't have the special Porsche unit.....14 x 1.5 mm WITH a semi-circular ball point-of-contact. Most Chevy truck 14 x 1.5's will be cone shaped.
- Wil |
| All times are GMT -8. The time now is 07:10 PM. |
