lagoon
Guest
Posts: n/a
fog light switch removal?
Have any of you had to remove the fog light switch at the dash? Does it come out in front or the back? I need to see if I have a loose connector. 81'SC
Old 11-21-2000, 04:04 PM
mark 74 carrera
Guest
Posts: n/a
I have the same question. My Fog lights don't work and I'm pretty sure it's the switch.
Mark Isaak
'74 Targa
Old 11-21-2000, 06:21 PM
tog
Guest
Posts: n/a
Plugs into the Foglamp and Defroster switches are accessible from the trunk behind the air ducting "mess". If memory serves me correctly, you can only access the plugged wires from the trunk. Removal of the switch is from the trunk --- after first unscrewing (from the dash side) the knob and the special locknut under it.
Old 11-21-2000, 08:26 PM
