Guest
Posts: n/a
Boxster wheels on a 77 S?
I am looking into some Boxster wheels for my 1977 S. Anyone know if they will fit without a lot of work???
Guest
Posts: n/a
I placed a second post just to get the topic back up top. Time is important as the deal I am looking at is being looked at by others! Any help is appreciated!
Guest
Posts: n/a
There is a massive difference in offset between the Boxster wheels and the wheels that were build for your car. I don't know if you actually can make them fit, but I do know that it's not easy.
It's the same reason you don't see Technology wheels on 3.2 Carreras (those you might have seen are replicas) |
Guest
Posts: n/a
Sorry I missed this one yesterday.
There are a number of people using 6 & 7 x 16 boxster wheels on pre '78 cars. I posted a similar question in August and got several replies. Unfortunately, a search has failed to turn up the best of the replies (one included a photo). If I can find it I'll pass it along. The facts as I understand them: Offset on the 6x16 is 50mm. Offset on the 7x16 is 40mm. I've verified the offsets first hand. 205/225 tire combination can be used but at least one respondent said they were using spacers. I can't remember the spacer sizes. I'm kind of counting on this working since I bought a set from Wheel Enhancement to use on '73 that is currently under re-construction. The suspension is competely off so I haven't been able to do any trial fittings for spacers,clearances etc. I'll look for the rest of the info and (hopefully) the Pic and re-post if I find them. Good luck. Joe |
