porsher
aston@ultrasw.c's Avatar
Car won't start - I messed up the wiring
86 Carrera
OK I know this was stupid
Track car - a/c, blowers, heat, fogs, radio, alarm etc... all gone.
I thought I would cut out all the extra wiring under the hood to tidy things up and reduce the risk of an errant wire causing a short etc....
Now the car won't start. Cranks but no start.
I cut the main harness adjacent to the wiper motor, everything cut with the exception of:
I remembered to connect the red/white and green/red that used to go to the alarm. Colors to not match the wiring diag but it was ok before.
I forgot the blue to blue/red for the alternator but I figured it out.
Car still wont start. What should I check for?
I just had a thought, I did not connect all the grounds, could ti be as simple as that?
Thanks in advance
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 05-23-2010, 05:03 PM
You need to see if it does not have spark or fuel i suspect no spark . Crank engine over with starter motor observe tachometer will cranking. Does tach needle pulse slightly look hard if it does not then you do not have spark. Did you cut wiring with battery connected? You may have damaged alarm control unit. Does alarm still work? Try the simple things first. Best regards and good luck. Will try to help more after response tom
Old 05-23-2010, 06:29 PM
porsher
you are correct - no spark; tach is dead
i did disconnect the battery first, no fuses blown
alarm is long gone
79 928 Race Car
Old 05-23-2010, 07:41 PM
porsher
I think I figured it out - i think i messed up the shorting links for the alarm delete.
it's too late now, i try again tomorrow
79 928 Race Car
Old 05-23-2010, 08:49 PM
porsher
Just in case anyone searches to my mistake...
be sure to connect the blue/red and blue wires (alternator)
and Black/red and black wires (DME signal)
anytime you disconnect or remove the alarm control module
79 928 Race Car
Old 05-24-2010, 07:13 PM
