Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 911 Technical Forum
VFR750's Avatar
Dash Pad Restoration Project
I have just completed my dash pad restoration. Here is a blurry picture of a ugly leather dash that was long past it's prime:
After a few weeks of work it now looks like this:
Here is a little presentation on my Project
3.7MB Power Point Slide Show
I have not installed it yet. It is 30F in the garage right now. So it will wait a couple more weeks before it goes in. Looking forward to seeing it when I an driving the car. The old dash pad was the only eyesore in the car.
Hope you like the presentation. I can add pictures if you have a specific question. Unfortunately I did not take picture of the cut plywood. The point of the plywood is to push the shelf covering into the step in the dash, and make a clean edge. The alternative would have been to sew the face and shelf pieces of fabric together before covering the dash pad. That was outside of my skill (and I don't have a sewing machine) So the plywood, and overlap joint became the alternative method to create the seam.
I used Neoprene covered vinyl fabric. It has a nice matte sheen, and is textured like leather.
BTW, I define the face as the part of the dash you look at when seated, and the shlef as the flat area, next to the windshield (package shelf).
Mike
Mike
'82 911SC, SSI, 22/29 tbars, 22F/22R Adj swaybars, Bilstein Sport, Elephant polybronze & monoballs, Cambermeister bar, turbo tierods, Carrera oil cooler, front brake cooling ducts, Sparco Sprint 5 & Recaro SRD PAX seat, Teamtech harness, DAS Sport rollbar.
Old 01-28-2007, 02:17 PM
Wow! Great job and presentation. More pix when installed!
Scott
Old 01-28-2007, 02:34 PM
scottb's Avatar
Excellent job, and great PowerPoint presentation.
1984 Targa
Old 01-28-2007, 02:47 PM
Beautiful work!
Warren & Ron, may you rest in Peace.
Old 01-28-2007, 03:16 PM
Used Up User
imcarthur's Avatar
Thanks for your efforts in documenting it. It took me a minute to figure out the role of the plywood but I finally understood. Good job.
Make sure to post an installed picture too.
Ian
'87 Carrera Cab
Old 01-28-2007, 04:27 PM
VFR750's Avatar
Ian,
It took a while to solve the seam problem. No one I knew had a sewing machine strong enough to go through the thick material. Plus, it's tricky seam joint. I was feeling like I was not going to be able to do it. So, I punted, and tried something else.
The plywood seemed like the best way to make a sharp, defined edge at the step. After some trials, I got it to work, and the end result is a good fit up to the step in the dash pad.
Mike
Old 01-29-2007, 02:12 PM
12 years and 17k posts...
azasadny's Avatar
Great work! Excellent documentation!! Thanks.
Art Zasadny
2010 MazdaSpeed3 (daily driver)
www.ford.com
Old 01-29-2007, 02:55 PM
Autodidactic user
David E. Clark's Avatar
WOW, really nice work! Thanks.
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 01-29-2007, 03:37 PM
SP2 SP2 is offline
SP2's Avatar
Mike,
Thank you for showing us how to do this. I have a 1969 dash that looks horrible. Now I think I know what I am going to do to fix that.
Why did you use neoprene cloth instead of leather again? Because it is more durable? Too cold here to do this now, but I will give it a go this summer. Really, thank you very much!
James
1969 911E Slate Grey
1981 911SC Wine Red
1997 911C4S Ocean Blue
Old 01-29-2007, 05:32 PM
excellent presentation
Old 01-29-2007, 05:43 PM
VFR750's Avatar
Originally posted by SP2
Mike,
I used the neoprene for two reasons: Cost and ease of use. Leather is sold in really big sheets, so it is expensive. I got quotes in the $200 range.
The neoprene looks nice and it is very stretchy. So I figured that would be easier to get it to match the contour of the dash pad. I hope it is durable. It is waterproof. So that should be one less worry, since water exposure is what ruined my dash.
Another plus, is the neoprene is over a layer of foam. So it feels very nice to the touch. Just a little bit of softness makes a difference. Regular vinyl would have a hard feel to it.
I did not consider the other materials, like suede. I wanted a leather substitute. It's not, but it looks nice.
Mike
Old 01-29-2007, 05:57 PM
Used Up User
imcarthur's Avatar
Stretchy is probably good considering the curves involved. I think somebody on the board used Alcantara but I don't know if it was a DIY.
Ian
'87 Carrera Cab
Old 01-29-2007, 06:23 PM
Drive's a 911 Every Day
Jason Cullen's Avatar
WWWWWWWOOOOOOOOOWWWWWWWW!
Old 01-29-2007, 09:28 PM
Designer King
Paulporsche's Avatar
Excellent job and presentation. Thanks.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L '80 SC engine/10.5:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rod ends; Bilstein HDs; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Goodrich G Force Sport Comp 2; PCA/UCR, MID9
Never leave well enough alone
Old 01-30-2007, 04:55 AM
WOW.... I got to hand it to you... I don't think I would have taken on that project. Now I really know why I became a member. GREAT JOB
Robert - 1985 Black Targa
SECOND CHANCE
Old 01-30-2007, 05:00 AM
Mike,
Thanks for all the info. I have a pretty badly warped dash. So your saying you can straighten it by using heat? Would love some more info on how you got it straight again. I originally thought i had to buy an entire new dash - but your project gives me new hope! Thanks so much for posting this.
Mike
Old 01-30-2007, 05:29 AM
SP2 SP2 is offline
SP2's Avatar
Mike,
Can you give us a source for the neoprene and the 2 dollar clips? Thanks.
James
1981 911SC Wine Red
Old 01-30-2007, 06:42 AM
Work in Progress
Rich76_911s's Avatar
Being that I don't have power point I cannot look at the presentation right now. Is there any other ways to see it?
Thanks for the information and the finished product is great.
Rich
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 01-30-2007, 06:48 AM
Autodidactic user
Originally posted by Rich76_911s
Being that I don't have power point I cannot look at the presentation right now. Is there any other ways to see it? ...
Rich
Download a free Powerpoint viewer from Microsoft here.
Old 01-30-2007, 08:05 AM
Great job & solution to a common problem. I'm interested in how well the adhesive holds up after setting in the sun for awhile. Keep us in mind & let us know.
Marv Evans
'69 911E
Old 01-30-2007, 08:17 AM
