orange peel
Painters, need suggestions on reducing orange peel using standard gun.
Old 01-29-2007, 09:18 AM
Hello,
Three main things, no matter what kind of paint or gun. I would trial various settings and spray some test panels keeping track of the settings.
1). Atomzing air
2). Fluid flow
3). viscosity
Other variables include evaperation rate of the reducing solvent used, part to gun distance, temperature and humidity.
Good luck
O2 In Sully We Believe
Old 01-29-2007, 06:33 PM
Mark is correct.
You need:
Proper air pressure (at the tip) for the product used.
Proper gun tip size (primer versus topcoat tip) and gun adjustment for the product used.
Proper reducer for the temperature and mix ratio for the product used.
Test your adjustments and vary your spraying technique until it’s right.
What is your "standard" gun...Siphon or gravity HVLP?
-Ernie
73 T...In a basket.
Old 01-29-2007, 09:49 PM
Sorry, by standard I meant siphon. My problem was not increasing pressure after using my HVLP primer gun. I upped the pressure and it lays down like glass. I guess I had an "oldtimers " moment.
Old 01-30-2007, 09:54 AM
Glad it's working out
Old 01-30-2007, 10:18 AM
