Garage dweller
Ducman's Avatar
Steering rack - what am I doing wrong?
Intending to replace tie rods so I thought I'd pull entire rack out - inspect, lube + it seems like it will be easier to remove old tie rods.
Anyway - tie rods are loose from the steering arms, steering input shaft is removed at the bushing, rack attachment bolts are removed - but I can't seem to find the way to fish that thing out!
The Haynes manual indicates that I need to "remove the right reinforcing crossmember brace" this brace is a permanent part of my crossmember? My crossmember is a tubular piece - I've seen a picture of a later unit that looked more like an H-beam with a removeable brace.
Even if this brace were removeable it doesn't look like I could get the rack out? Do I need to lower the whole crossmember? Can I do this without removing front t-bars? Other options look to be removing the brake MC and lines - this doesn't thrill me either.
Help
Thanks,
Don
Don Sjolin
IIIEURO AUTOWERKS
616.874.7932
Old 01-29-2007, 08:23 PM
randywebb's Avatar
the Xmember needs to be removed
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 01-29-2007, 09:26 PM
Garage dweller
Ducman's Avatar
Looking at this some more - is there any reason I can't carefully lower the crossmember without disassembling everything? i.e. remove the front a-arm mounts, remove crossmember mounting bolts and then just lower enough to gain clearance to slide rack out.
Thanks,
Don
Don Sjolin
IIIEURO AUTOWERKS
616.874.7932
Old 01-31-2007, 05:36 AM
Garage dweller
Ducman's Avatar
I tried a search using a different term and got my answer - looks like I can easily drop the crossmember.
Thanks,
Don
Don Sjolin
IIIEURO AUTOWERKS
616.874.7932
Old 01-31-2007, 06:10 AM
randywebb's Avatar
post the good & bad terms for the next guy...
good luck on the project
Old 01-31-2007, 10:59 AM
This thread is the best source I have seen for info about rebuilding the rack. I am a proponent of pulling and lubing the rack when doing the tie rods. It only takes a few extra minutes and makes getting the rods off-on significantly easier.
gary
Old 01-31-2007, 12:08 PM
randywebb's Avatar
There was recent thread by a guy who left the rack in place and pumped in new grease.
- what do people feel about the advisability of that?
Old 01-31-2007, 02:05 PM
