Czar of C.R.A.P.
Go to the Stan Weiss site and compare.
66 912 Coupe 84 Carrera Cab Hardtop HC3.4 Hyper Carrera 2005 Dodge Magnum 5.7 HEMI Cabriolet Racing And Performance C.R.A.P. Gruppe #1 Put on some C.R.A.P. and drive.... |
Interesting. They do look very close. The 0280-150-826 on Ebay has flow specs listed on Stan's site, but not the pressure at which they were taken, which is a little iffy to me. Suppose Chrysler's FI operates at a higher or lower press?
What is the feeling on the difference in flow rate? My gut feeling is that if the flow rate is off by very much at all, you will get either a lean or rich condition, since the ECU will be varying the pulse time according to its maps, but will have no knowledge of the actual flow rate of the injectors. Then there is the physical dimension thing: how about the injector's length and the diameter of the nozzle which fits into the intake? Did I read earlier that these are standard? ianc
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 |
Now that Troy is all sorted out -give these Folks a try (let us know if the posted price still holds)
http://germancarsandparts.com/index.html Fuel Injector Part #: 0280150158 Price: $84.95 Note that this Bosch number also fits 944 (2/1985-88). 911 (1984-89). 924S (1987-88).
1995 993 ('Under my Care') 1989 911 ('Go Pitt') 1996 993 ('Go Navy') 1984 911 ('Go Pelican') |
Czar of C.R.A.P.
Bill is Dead.
Lot's of people buy reconditioned injectors and are happy enough.
However, my uncle works for Bosch. He has worked his way up from working the FI assembly line, working the QC (including production testing), and now works as a liaison to auto manufacturers. I mention this just to establish his background of knowledge. And here is summary of his advice to me. Don't do it. As mentioned in this thread, "reconditioning" simply means that the injector has been cleaned and flow tested. It's still a used injector with an unknown number of cycles on the solenoid. The body is a sealed unit. The solenoid cannot be replaced, and more importantly the internal "valve core " cannot be replaced. How long will your bargain perform before the needle, seat, or return springs give out?
-.-. .- ... .... ..-. .-.. -.-- . .-. The souls of the righteous are in the hand of God, and no torment will ever touch them. |
You are correct... however... my injectors were already 20 years old, so I was in that boat already where they could fail at any time. My choices were to buy a single new injector to replace the one that had failed for me... $160-ish and leave my others in place where any one of them could fail any time. Or, buy a fresh new set at $165 a pop.. Or buy a cleaned, usedm flow matched set for $240. At $40 a plug... I'll do this for the life of the car and come out smelling like a rose. My bet is that the injectors I purchased will have at least another 10 years in them. If not... I can affort to buy 6 more and plug and play as problems arise.
-Troy
1986 911 Coupe (Guards Red), Fabspeed Euro Pre-muffler, Steve Wong Performance Chip 2001 Boxster 2.7L (Orient Red), bone stock |
Well, I took a good look and had a good hard think about those Chrysler injectors that dfink posted a link to on Ebay. How tempting!
But, after some further study, I'm convinced they won't work from a physical fitment point of view. If you look at the 158 Carrera injector: The groove for the attachment clip is considerably higher up on the inlet side than on the Chrysler injector: Other than that they appear very similar, but I think that one factor would prevent the bracket on the intake from holding the injector at the proper height to get a good seal in the intake. Another route might be some of the VW injectors, as Stan's web page shows them to be very similar as well. Not sure of prices there though; they might be just as much as the 158... Fiddle. This is becoming rather vexing... ianc Edited to say: I heard back from Holley this AM, and they say that the Holley part # dfink found (68-49), has been discontinued...
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 Last edited by ianc; 03-02-2007 at 10:08 AM.. |
Thought I'd bump this again for a progress report to anyone interested. The six 150-201 injectors that I purchased from FiveO have been in my car for over 7 months now. I commute 80 miles a day 5 days a week and haven't had a single hiccup. I have since put a Steve Wong chip in and a Fabspeed Euro pre muff... the car runs great. I can honestly say that I can recommend with confidence the Bosche 150-201 injectors as a direct drop-in aftermarket replacement for the 3.2. I paid $259 from FiveOMotorsports for a FULL set. Flawless.
-Troy
Czar of C.R.A.P.
I just ordered a set of BRAND NEW injectors for my 89 3.2 from Fiveo... for $259
Quote directly from the webpage... 984-89 Porsche 911 Carrera & Speedster Bosch 0280150159 Brand New Sets $259.50/Set 6 Link... http://www.fiveomotorsport.com/Injector_SetsPORSCHEVW.asp Did I miss some fine print?
Current Car: 2004 Carrera 3.6 Targa, Arctic Silver/Metropol Blue Prior Car:1989 Carrera 3.2 Cabriolet, Guards Red/Cashmere Beige |
Czar of C.R.A.P.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
Czar of C.R.A.P.
The 0280-150-159 appears to be a low impedence injector. Fuel ratios may be off a bit as it is a higher flow rate injector. It makes me wonder though why they are so much cheaper. May just be the porsche tax at work but still makes we wonder what the differences really are.
Very hard to find good specs on Bosch injectors. From what I understand even the ones posted on the internet are just compiled from different sources that have tested the injectors. Bosch it appears does not release the specs. Dyno tests and O2 readings on the injectors would be interesting.
PorscheSki89,
Sounds like a great deal. Did you speak with them on the phone? Any info? Please let us know how they work... ianc
Royal Purple/Lilac, Signal Orange, Guards Red |
Per the Stan Weiss site, the 159 is 24.35 lbs\hr, and the 158 is 21.8. No pressure at which this measurement was taken was listed for the 159 however. The 158's press is listed at 36.25 psi.
ianc
Here's something that may be helpful, it's the largest list of injectors I've ever found:
http://www.members.lycos.co.uk/maxboost/docs/Bosch_Injector_Applications.pdf Then take a look at part num 'E4EX-9F593-AA' sure looks like that injector may be a match for the 3.2L.
As mentioned earlier the 0280-150-159 bosch injector does seem like the correct one for our 3.2L Carreras.
First it is listed at FiveO as the one they sell for our cars see here: http://www.fiveomotorsport.com/Injector_SetsPORSCHEVW.asp Also you will find specs for this injector and hundreds of others here: http://users.erols.com/srweiss/tableifc.htm#BOSCH The site with all the specs shows the bosch 0280-150-159 injector as low impedance and 24#. Here's the rub: they most likely where flowed at 3 bar (most are rated at 3bar) but our cars run 2.0 to 2.5 bar presure not 3.0 and calculations I ran for a 3.2L pushing 230HP with 2.5bar presure show estimated flow of 240cc/min about 23# if you adjust this to figure out what kind of flow rate that equates to at 3bar you get about 25# injector (265cc/min) So maybe this injector is a tad on the light side but our Motronic system will compensate and just drive it a little harder. The orginal number I calculated was at 80% duty cycle so I figure the 24# injector has enough head room. My bet is it will work just fine. You can get the calculators here: Fuel presure adjustment calculator http://users.erols.com/srweiss/calcpchg.htm 3.0bar is 43.5lbs and 2.5bar is 36lbs Injector size calculator is here: http://www.injector.com/injectorselection.php This calculator shows a 6cyl 230HP at 3bar needing just under 24# injector at 80% duty cycle. Our cars run about 2.5bar not 3bar so a 24lb injector may be a tad light. dfink posted that he bought these, let us know how they work. Good luck. Also FiveO sells them for our cars, I'm sure if they did not work they most likely would have heard from customers that bought them. Hope this is helpful.
Czar of C.R.A.P.
The motronic system will only adjust in the range where the O2 sensor is functioning. Otherwise it is a straight fuel map to the position of the MAF sensor. With a bigger injector it should be rich at WOT as the pulse will be same just more fuel passing through.
