mikeatfhc's Avatar
Lic Plate Lights wiring -78SC
Trying to avoid a possible ticket...
I am going to return lighting to the rear lic. plate lights located at the bumperettes. The PO's shop cut the wires during a motor install (I assume). They are too short to reach past muffler and I cannot locate for sure the source wiring to hook them back up.
I think the originals are located in the rear fenders, near where the wire loom mounts go through the engine compartment but I don't see anything hanging around in there.
Does anyone know where the source wires are located?
I'd rather not pull the muffler to get access - can you remove the bumper without removing the bumperettes?
thanks.
'78 SC Wide Body, '81 Engine. M&K 1in2 Out, Carrera Sways, ER F&R rear monoballs, ER control arm bearings, ER spring plate bearings, turbo tie-rods, ER strut brace, Tarret Drop links, Bilstein custom-valved shox, Rebel Racing bump-steer kit, 22mm F, 28mm R TBs. Rebuilt calipers, new wheel bearings.
Old 01-30-2007, 10:26 AM
Tired Member
DaddyGlenn's Avatar
If I remember correctly from my recent engine drop....
I think saw the wires following the inside of the rear bumper to the connectors that carry the power to the taillights.
I think...
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 01-30-2007, 11:03 AM
Re: Lic Plate Lights wiring -78SC
Yes. Bumperettes can stay on.
911 Grand Prix '81 Euro SC (sold)
2002 BMW R1100S - "Daily Driver"
2004 BMW E83 "snow machine"
2006 BMW E90 "Euro Delivery"
Old 01-31-2007, 08:50 PM
mikeatfhc's Avatar
I have he Bently - but it states to pull the bumpettes first to gain access to remove the trim rubber - so I assume I can remove the trim rubber from under the bumperettes to gain access to the bolts that hold the muffler on?
Thanks for the help.
Old 02-01-2007, 07:04 AM
Yes, the rubber trim strips can be removed, to access the bumper nuts, without first removing the bumperettes.
JR
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle
Old 02-01-2007, 07:24 AM
emac's Avatar
Mike
I went a little further back and got to them behind the taillights. Very easy access.
Ernie 81 SC
Old 02-01-2007, 07:33 AM
mikeatfhc's Avatar
Thanks JR, I'll give that a try. I cant reach the bumperettes nuts from behind because of the muffler (too little room) - so being able to take the bumper off without having to remove the muffler will save a lot of time.
emac - can you explain a little more? Are the wires in the tail light loom?
Old 02-01-2007, 08:33 AM
Why not run a pull wire through the bumberette and connect your wires to that and pull them in?
There is a small hole in the rear bumper behind the bumperette.
Silver 1980SC Euro coupe
Old 02-01-2007, 08:43 AM
emac's Avatar
Mike
When I removed my taillight asmb. there was a large loom of wires wrapped with tape. But I seen as I recall two wires running to the rear of the car. I was able to follow them back to the plate lights.
Ernie 81 SC
Old 02-01-2007, 09:47 AM
Rick Crider's Avatar
Mike .... if it helps any, I have photos of entire rear section .... wide open views with bumper removed for stainless exhaust install.
In the photo posted here, the license light leads are the long ones dangling far left and far right. Two wires on each side (+/-), sheathed together in single brown vinyl tubing. ('76 930 .... likely the same for '78 ... ???)
More photos / different angles HERE .......
Hope it helps a bit .....
Rick
1976 930 Turbo Pelican Gallery Page
1989 911 Cabriolet (Sold)
2000 A. M. General Hummer
1961 Alfa Romeo Giulietta Spider
Old 02-01-2007, 10:34 AM
mikeatfhc's Avatar
Excellent - thanks all.
I did see the two wires dangling and figured that has got to be them, however when I tried testing them with a voltmeter they were dead. More investigation is in order...
Rick - absolutly awesome 930. Your photos are a big help... OT, but I have a broken fender extension strut, the short one in the back, do you know if the 930 and 911 narrow body fender extension struts are the same?
Old 02-01-2007, 11:00 AM
They should be the same.
JR
Old 02-01-2007, 12:08 PM
Back in New England!
MattAlpha's Avatar
Send a message via AIM to MattAlpha Send a message via MSN to MattAlpha
do your fog lights work? I noticued that when I was trouble shooting my non-operational fog lights that the license palte lights were also not functioning when my running lights were turned on. Once I fixed the fog lights (PIA do to several things being broken), the last thing I replaced was the fog lamp fuse in the long fuse box on the driver's side in the trunk, and my license plate lights began to function.
Just a thought of a way to deliver power to those wires you think are for the license plate.
'78 RoW 911SC Targa converted to a '86-like 3.2L Cab (w/930 body & No A/C) Custom subframe integrated into AutoPower Half Cage, Euro Ride Height, Turbo Tie-Rods, WeltMeister Bump Steer Kit, Sway-Away 26mm Rear Torsion Bars, Koni Adjustable Shocks and Strut Inserts, Two Bar Rennline Strut Tower Brace, Poly Motor Mounts, WEVO Trans Mounts, Modified Conical K&N Intake, ER PB A-arm bushings and 17" CUP3 Wheels. Steve Wong Chip!
Old 02-01-2007, 12:14 PM
steve911's Avatar
Mike--
Just a thought - did you have the headlights on when you tested them? Pretty sure that the license plate lights only work when headlights are lit...
BTW, if anyone knows what the replacement bulb number is, I'd be most appreciative. The existing bulbs have no markings and the Bentley information is wrong (wrong bulb #).
My '85 911 Targa ** Hand painted center caps for sale here
RIP Warren
PCA & Rennlist member
Old 02-01-2007, 01:24 PM
mikeatfhc's Avatar
Fog lights are working, fuse #2 is good - The Bently electrical diagrams show the lic plates lights and the fog lights power originating from this fuse; I did pull it and now have non-functioning fog lamps to protect the wiring from any shorts that may be causing the lic plate lights not to work.
I didn't test the wires with the headlights on as I recall; I think I only tried it with the parking lights on, maybe that's why I'n not getting voltage at the hanging wires. Definately worth a look.
Old 02-01-2007, 01:53 PM
>>>SNIP>>>>
Thanks for the kudos, Mike ...
....on the fender strut question, I'm just not *sure* but I believe it to be the same ....
Rick
>>>----> EDIT: .... duh .... just spotted Javadawg's answer, directly under your question .....
Old 02-02-2007, 03:57 AM
