Browzer52's Avatar
loud air cond.squeel
Last time I used my air conditioning there was a rather loud annoying squeel on the passenger side of the car.This is the time of year to address the problem,any input would be most appreciated.
Old 02-04-2007, 06:17 PM
david914's Avatar
Common problem. The blower motor bearings dry out prematurely due to the cold and dry environment they live in. If it's just an occasional or mild squeak, you can probably get by with lubing up the bearings for a while. If it's screaming like a banshee, you'll want to just replace the motor.
Personally, next time I have to crack mine open to lube it, I'm going to fab up some sort of remote oiling tubes that can be reached from inside the smuggler's box. Too much of a pain to work with as often as this needs to be done!
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 02-04-2007, 06:33 PM
Check for loose A/C drive belt.
