Oil Pressure
Hi!
1974 911S 2.7 Car runs, sounds awesome. Normal puffs of smoke on start-up, totally gone within 2 min. Zero oil leaks. On start, oil pressure is steady at 0. When pushing the throttle, the preesure goes to max… Someone know what the problem is? Thanks! Joachim Myhre
- 1974 911S 2.7 |
your pressure should be around 1 bar which would be around 1000 rpm at idle. pressure should rise and follow rpm range.
- Tyler 1988 911 Carrera Grand Prix White/Black 2015 Cayenne Diesel Black/ Luxor Beige/Black |
Thans for aswer! Is there anything I can do to fix this?
- 1974 911S 2.7 |
