engine shroud
Hey guys,
I saw this new engine-shroud for sale at a reasonable price.
My original shroud has some cracks and the airduct is broken...
So I thought, just buy this new one instead of repairing the one I have.
Will the shroud in the picture fit on a 2.4 MFI-engine?
Johan
Old 02-06-2007, 04:26 AM
Hi Johan,
Not without some modifications like drilling out the 3 holes on the rear for the MFI pump mounting plate. You will also have to notch out the six large holes for the injectors. You will also have to drill a hole so you can adjust the MFI pump through the fan.
The elbow area on the right rear looks like it has been painted, normally that is gray in color. I would ask the seller if the entire shroud has been painted and if so how was it done. The engine heat could cause the paint to fail at some point.
Brian
'73 Carrera RS
'71 911S coupe 'Patrick'
'16 Cayman GT4
'91 C4 coupe
Old 02-06-2007, 10:38 AM
