85 Targa
White smoke
Never had it before I had my oil changed. Now a lot of White smoke comes out the muffler now. Could they have put to much oil in? My oil gage is at the highest level. I check the stick and it is pass both notches. 3/4 of the way up the stick. Should I just drain a little? Will this solve my problem................Thanks for any help!!
white smoke would typically indicate condensation in the exhaust, does it burn off after a few minutes idle, or does it blow smoke on acceleration / deceleration?
1984 911 Coupe 2007 Z4 M Coupe 2008 Cayman S 2004 M3-Alpine White(sold) 2002 M Roadster (sold) |
Vafri
How much oil did they put in the tank? If it's more than 10 quarts it could be above the high mark as the oil cooler lines and trombone hold about 3 quarts or so. You might want to drain out a couple of quarts and try that. If it stops smoking when you do, then run the car up to running temp and recheck the level with the car running, at operating temp, on level ground and readjust the quantity.
85 Targa
if you drain any oil, make sure you do it cold... not warm...
dont ask me how i know...
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
83 911 Production Cab #10
What grade/brand of oil is in now? Also check this thread; how to diagnose smoke on start up?
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Drain the engine sump, that should be a few quarts, depending on how long its been standing. Its easy to add more oil if drain to much, use a clean container and you can reuse the oil if you need to add some. I would not return to that shop for any more work in the future. Go so someone who knows Porsche or do it yourself.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
The oil should be between the 2 marks. You have too much oil in there; probably a couple quarts too much at least.
I'm sure you know to only check the oil on level ground, operating temperature and with the engine idling. You should leave the engine running a minute or so before checking. Do not check with the engine cold and not running. Sorry if you already know this. The oil level will be higher at operating temp than when cold - oil expands. |
